Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2002 Dodge Stratus stereo wiring diagram
Old 03-26-2007, 10:46 PM
blach's Avatar
blach
blach is offline
Default 2002 Dodge Stratus stereo wiring diagram
i need to know where to find the radio color diagram for FREE.....everywhere i go they tell me i have to pay.....thanx
Old 03-26-2007, 11:05 PM
rtkota5point9's Avatar
rtkota5point9
rtkota5point9 is offline
Default RE: 2002 Dodge Stratus stereo wiring diagram
Stratus Coupe (Made by Mitsubishi)
Constant 12V - Orange/Black
Accessory - White/Black
Illumination- Green/White
Left Front Speaker (+) - White Blue
Left Front Speaker (-) - Black/Blue
Right Front Speaker (+) - White/Red
Right Front Speaker (-) - Black/Red
Left Rear Speaker (+) - Yellow/Blue
Left Rear Speaker (-) - Gray/Blue
Right Rear Speaker (+) - Yellow/Red
Right Rear Speaker (-) - Gray/Red
Stratus Sedan (Made by Dodge)
12V Constant - Pink
Accessory - Red/White
Illumination - Orange/Brown
Left Front Speaker (+) - Green
Left Front Speaker (-) - Brown/Red
Right Front Speaker (+) - Purple
Right Front Speaker (-) - Blue/Red
Left Rear Speaker (+) - Brown/Yellow
Left Rear Speaker (-) - Brown/Light Blue
Right Rear Speaker (+) - Blue/White
Right Rear Speaker (-) - Blue/Orange
Hope this helps! And of course the ground is a seperate wire or chassis.
Old 03-29-2007, 12:38 AM
civic96lx's Avatar
civic96lx
civic96lx is offline
where did you find that? anything on a 99 intrepid? 4dr...
Old 03-29-2007, 01:49 AM
rtkota5point9
Constant 12V - Pink
Dimmer - Orange
Antenna Turn on - Orange/Red
Left Front (+) - Dark Green
Left Front (-) - Brown/Red
Right Front (+) - Purple
Right Front (-) - Dark Blue/Red
Left Rear (+) - Brown/Yellow
Left Rear (-) - Brown/Light Blue
Right Rear (+) - Dark Blue/White
Right Rear (-) - Dark Blue/Orange
I get my info from database at work. But you can find quite a bit from the12volt.com as well. They have wiring for a lot of vehicles. And it's free. You can access our database at work from anywhere, but you have to have a password. And I can't give it out of course
Old 03-29-2007, 05:45 AM
habeba86's Avatar
habeba86
habeba86 is offline
Do you use directechs at all?
Old 03-29-2007, 01:52 PM
rtkota5point9
Yup, we use Directechs as well. And MAID and Wire Magic. They're all pretty good, but they do screw up every once in a while. For example, look at Directechs under 05 Hummer H2 and look at locks, it says (-) trigger at purple plug at BCM. That's B.S.! For one, one of the pins they say doesnt even have awire in it, and the other one is the wrong color. lol I found all the other doors and rear gate, but not the front doors. It's just like a silverado, you have to use a 457G (1700G now). Because the module is IN the door. I've emailed them a few times and it's still on the site. lol
But they are pretty good about most things. And MAID is usually spot on, but they screw up speaker sizes quite a bit.
Old 03-29-2007, 10:29 PM
habeba86's Avatar
habeba86
habeba86 is offline
Never heard of maid...... The actual CC wire guide's are usually wrong about some wires most of the time.
Old 07-15-2007, 05:15 PM
jdoggwh's Avatar
jdoggwh
jdoggwh is offline
I NEED HELP ON THE WIRING COLOR CODES FOR A 2002 DODGE DAKOTA QUAD CAB!! IF ANYONE CAN HELP PLEASE LET ME KNOW!! IM TRYING TO INSTALL A NEW RADIO AND IM STUCK RIGHT THERE I DON'T KNOW WHICH IS WHICH!! THE POWER, OR SPEAKER!! PLEASE LET ME KNOW!!
Old 07-15-2007, 07:20 PM
rtkota5point9
First off, stop yelling. J/K Why not just use a metra wiring adapter? It's reversable, easier, and no guess work.
Old 04-19-2011, 10:14 PM
Decyfer's Avatar
Decyfer
Decyfer is offline
Default Remote Turn on for amp in the 02 Stratus coupe.
Could you tell me what color is for the remote turn on for the factory amp? I have An 02 Stratus RT Coupe
Quick Reply: 2002 Dodge Stratus stereo wiring diagram
