2005 cummins wastegate problem
Old 03-24-2007, 08:30 AM
swissguy's Avatar
swissguy
swissguy is offline
Default 2005 cummins wastegate problem
A friend of mine has a 2005 Dodge Ram.
A couple of days ago he got the CEL, with a code someting about wastegate pwm signal...
I did a look at his engine and saw there is a cable teard out from the wastegate and it is not reparable.
I think the part i`m talking about is the wastegate-assemly and not a solenoid. The Part is locateted direct on the turbo, has a connector with 2 cables and a vacuum hose on it.
Is the part available seperatly and how easy is it to replace? Is it just screwed in or do whe need to take the turbo a part? were can we order the new wastegate, only at Dodge Dealerships or are there any aftermarket vendors?
thanks for any help swissguy
Old 03-24-2007, 10:51 AM
cumminalong's Avatar
cumminalong
cumminalong is offline
Default RE: 2005 cummins wastegate problem
Swissguy....Welcome to DF!
2005.......ain't he still got a warranty or is he running a bit "hot" and doesn't want to take it in?
Old 03-24-2007, 04:17 PM
swissguy's Avatar
swissguy
swissguy is offline
He has no warranty here in Switzerland, because it is a grey import.
But he want to fix the problem anyway.
Old 03-24-2007, 05:57 PM
Drew's Avatar
Drew
Drew is offline
did the wires break off or what???
Old 03-24-2007, 06:18 PM
swissguy's Avatar
swissguy
swissguy is offline
yes, one wire break off, because a hose was rubbing on it.
Old 03-24-2007, 08:46 PM
Drew's Avatar
Drew
Drew is offline
I would say you should be able to just splice the wires back together. lenghten them a bit so you can pull them out of the way of rubbing.
Old 03-24-2007, 11:55 PM
swissguy's Avatar
swissguy
swissguy is offline
no way to splice, connect or solder them, because there is not a bit of wire on the wastegate anymore.
Old 03-25-2007, 12:40 AM
Drew's Avatar
Drew
Drew is offline
have you pulled the connector on the waste gate actuator to see if the pin is still there?
Old 03-25-2007, 01:21 AM
NickBeek's Avatar
NickBeek
NickBeek is offline
If the pin is still in the connector, you should be able to remove the pin and reconnect the wire (solder) to it then reinstall the pin into the connector. Some one post the link to the service manual for him. I think the SMeven tells you the tool you need to remove the pin from the connector.
Old 03-25-2007, 08:00 AM
swissguy's Avatar
swissguy
swissguy is offline
The connector-side is not the problem, there is the wire still ok. The wire is brake off from the wastegate-housing! No pin there only the sealing compound.
Quick Reply: 2005 cummins wastegate problem
