code p0320
Old 03-13-2007, 12:52 AM
tman's Avatar
tman
tman is offline
Default code p0320
my wifes 2000 durango is hard to start sometimes &idels rough . it set code p0320 where do i start at to try to fix it?????????????????????????????????????????????
Old 03-13-2007, 02:14 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
Default RE: code p0320
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
https://dodgeforum.com/m_614377/tm.htm
It looks like you need a tune up.
Old 03-13-2007, 07:45 PM
tman's Avatar
tman
tman is offline
i just changed the plugs. & it didnt help its still hard to start and stumbles and dies when check engine light comes on its code p0320
Old 03-15-2007, 10:01 AM
tman's Avatar
tman
tman is offline
any ideas? im leaving for florida in a week i need to get this fixed.....hellllllllllp[]
Old 03-16-2007, 05:59 AM
Mean Green's Avatar
Mean Green
What kind of plugs are you using? Just a little info if it is pretty much anything other than champions then they suck in our engines that may be your only problem. I tried running bosch plat's and couldn't keep my engine running on them. got some champions and had the smoothest idle.
Old 03-17-2007, 04:40 AM
tman's Avatar
tman
tman is offline
there champions. it doesnt do it all the just every once in a while
Old 03-19-2007, 01:33 PM
Dodge Tech's Avatar
Dodge Tech
Dodge Tech is offline
need a crank and cam sensor the crank is the issue but replace both for **** and giggles
Old 03-20-2007, 12:56 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Could be the wires. You should use OEM only. There are a couple of others like MSD or such. Stay away from Bosch and other replacement wires from regular auto part stores. Also it helps to know what motor you are working on. [>:]
Old 03-20-2007, 09:21 PM
tman's Avatar
tman
tman is offline
its a 4.7 it doesnt have plug wires
Quick Reply: code p0320
