Lights Dimming
Old 03-08-2007, 12:16 AM
FroneDaddy's Avatar
FroneDaddy
FroneDaddy is offline
Default Lights Dimming
When it's cold outside and I first turn my truck on all my lights dim for a minute or so and then get bright again, and this continues for a while. When they dim I hear a clicking noise on the passenger side of the engine compartment. The stealership tells me this is normal, and the noise is a heater that heats the air going through the intake and the lights are dimming because the heater draws so many amps. Does this sound right?
Old 03-08-2007, 12:23 AM
thib's Avatar
thib
thib is offline
Default RE: Lights Dimming
The stealership is right. I have an 06 and it does the same thing. It will keep doing it until it is warmed up
Old 03-08-2007, 12:45 AM
cumminalong's Avatar
cumminalong
cumminalong is offline
Perfectly normal. It's your grid heaters cycling on and off. They draw a huge amount of current.
Nothing to worry about.
Old 03-08-2007, 01:14 AM
RobertDunn's Avatar
RobertDunn
RobertDunn is offline
HMMWVs (Military hummers if you don't know the acronymn) do the same thing.
Old 03-08-2007, 01:15 AM
trbodiesel's Avatar
trbodiesel
trbodiesel is offline
yeah lots of amps... look at that voltmeter swing too.
Old 03-08-2007, 01:53 AM
Greg Swartz's Avatar
Greg Swartz
Greg Swartz is offline
Wow. I have the same issue (I guess we all do.) I thought it had something to do with the alternator and battery, and maybe some cycling going on.
Thanks for the heads up.
Old 03-08-2007, 02:05 AM
Greg Swartz
Good 'ol military HMMWVs... Yep, I remember that now.
Old 03-08-2007, 04:05 AM
handymanherb's Avatar
handymanherb
handymanherb is offline
Cummins is in the Hummer too!
Old 03-08-2007, 04:50 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
would that happen if ya had dual batteries??
Old 03-08-2007, 04:59 AM
thib's Avatar
thib
thib is offline
There is two batteries. The heaters just draw up lots of amps.
Quick Reply: Lights Dimming
