Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Sponsored by:
Sponsored by: Mall of Georgia
OIL CHANGED TO SYNTHETIC???????
Old 08-23-2004, 08:55 PM
wildwolf59's Avatar
wildwolf59
wildwolf59 is offline
Default OIL CHANGED TO SYNTHETIC???????
Hey guys......new dodge owner here....used to own the chevy but from now on its the dodge. I bought a 2000 quad cab 4x4 with 55000 miles on it and i was wanting to know if you guys thought it would hurt anything to change it from the regular oil to the synthetic with that many miles on it and if you thought it would hurt anything. I know the other truck i had they started out on it from the beginning but this didnt and i dont know if i should change it to the synthetic from the regular.......Please give me any input that you can.....thanx and i look forward to talking with you guys!!!!!!
Old 08-23-2004, 08:57 PM
wildwolf59's Avatar
wildwolf59
Default RE: OIL CHANGED TO SYNTHETIC???????
i know you have the poll going but justed wanted to know the thoughts on it
Old 08-23-2004, 09:28 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
I did my truck when I got it (high miles @ 121k) and I have no problems. I also did the BMW @ 135K and no problems.
I recommend mobil 1 (I use 15w50).
Old 08-23-2004, 09:45 PM
wildwolf59's Avatar
wildwolf59
Steve....is there a reason why you chose 15w50 rather than 10w30 or 10w40.......just curious?
Old 08-23-2004, 11:51 PM
dodgefreak's Avatar
dodgefreak
dodgefreak is offline
I have used Moble 1, Royal Purple and AMSOIL and did not notice a difference in any of them, though they are all greatly better than reg oil.
I now stay with Moble 1 for the price.
Old 08-25-2004, 12:17 AM
millenniumdna's Avatar
millenniumdna
millenniumdna is offline
if you check out mobil 1's website you can find some intresting info on myths about syn oil
http://www.mobil1.com/index.jsp
It appears if im reading this right you can change a car over at any time.
Old 08-25-2004, 01:28 PM
grayghost's Avatar
grayghost
grayghost is offline
I use Mobil1 on mine, although I did not have alot of miles on it when I changed my oil over to synthetic. I did alot of research on the subject and the only thing that I found is that you should not use synthetic for the break-in. Other than that you should be able to make the switch at any time regardless of the miles that are on the vehicle.
Old 08-25-2004, 01:47 PM
steve05ram360
ORIGINAL: wildwolf59
100 degree sacramento summer days, I've tried 5w50 in my Jeep 5.2 & felt like it was not protected well enough... if felt loose and made more noise than with the 15w50. so in my mind that equaled less protection on the cylinder walls & bearing journals so I switched to the 15w50 & haven't used anything else since. I also tried this on the BMW motor & felt the same way with how it ran. A rebuilt BMW motor is $3500... ouch (doesn't include labor), I'll stick with the 15w50 mobil 1 oil. The only drawback is in the winters when i go tothe mtns...takes a little bit to get it warmed up, but for the most part, here in Sacramento, we have very mild winters (30's and never any snow) so it's not a problem
Old 08-28-2004, 02:41 AM
sgbofav's Avatar
sgbofav
sgbofav is offline
ORIGINAL: steve00ram360
You should have your oil tested and see how your oil is really doing. Feelings and sounds are not an accurate indicator. There are several brands of vehicles that now run 5w-20. The long term oil analysis results have proven that the thinner oil has protected the engines flawlessly. This is contrary to what all the "thicker is better" crowd said would happen. Read some of the oil analysis results at www.bobistheoilguy.com and see for yourself.
I use a synthetic diesel 15w-40 in my 5.9 Ram because it has 137,000 miles on the engine. In my Dakota (67,000 miles), I use a synthetic diesel 5w-30.
Old 09-02-2004, 10:51 PM
cdubya's Avatar
cdubya
cdubya is offline
i just switched to synthetic for the price difference. $32 for 3000 miles or $50 for 6500 miles. Maybe i am wrong but it makes sense to me, a penny a mile or seven tenths of a penny a mile. Plus it provides better protection.
Quick Reply: OIL CHANGED TO SYNTHETIC???????
