Dodge Magnum The Dodge Magnum, the wagon that made wagons cool. The unique look of the Dodge Magnum makes any trim level, from SE to SRT-8, an absolute head turner.
RKE Battery Low
Old 02-26-2007, 03:25 PM
2005 Magnum R/T Hemi's Avatar
2005 Magnum R/T Hemi is offline
Default RKE Battery Low
I got an error on the Computer read-out this weekend, but it seems to have went away. At least for now... Does anyone know what the RKE Battery is? Is it the Main Battery for the Car, or some Computer related battery? Just wondering what to replace before it is too late. Any input would be appreciated!
Old 02-26-2007, 05:02 PM
MangoInTX's Avatar
MangoInTX
MangoInTX is offline
Charger Moderator
Default RE: RKE Battery Low
My first guess is Remote Keyless Entry... the battery in the key.
Old 02-26-2007, 06:08 PM
510 HEMI's Avatar
510 HEMI
510 HEMI is offline
Yup i had that as well it means Remote Key Entry battery is low i had to get mine reprogrammed as well my battery was too low.
Old 03-13-2007, 01:32 AM
rgdawson's Avatar
rgdawson
rgdawson is offline
I just started getting this system warning also, "RKE Battery Low". So taking a wild guess, I replaced the battery in my key. Well, nice try, I guess, but that wasn't it. I called the dealer and they said, of course, "You have to bring it in so we can diagnose it." I'm thinking, wait a minute, didn't this thing just diagnose itself? Anyway, if it is not the battery in the key, what is it?
Old 03-13-2007, 03:08 AM
DrKaos's Avatar
DrKaos
DrKaos is offline
Do you have the factory car starter? If you do, according to DMX when you start the vehical using the command start you will get a message in system warnings on the EVIC saying "RKE Battery Low" Mine has done this since day one.
Old 03-13-2007, 10:32 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Nice you tried the battery... I guess
Don't know what else it would be besides the battery. Could the battery you replaced it with possibly be bad? Not every battery on the shelf at the store is good.
Old 03-14-2007, 01:02 PM
LtlDad's Avatar
LtlDad
LtlDad is offline
There is an issue with the solder connections inside the key fob. I just re-soldered one side of the connectors to correct. If you have dropped your keys or have a 'early build' (mine is 06/04), then you might have the solder connection issue.
Old 03-15-2007, 02:51 AM
magmagnum's Avatar
magmagnum
magmagnum is offline
We ended up with a new key , under warranty for this problem.
Old 03-25-2007, 02:06 AM
rgdawson's Avatar
rgdawson
rgdawson is offline
I'm thinking now it is the key itself, because if I use my wifes key, the message goes away. Since the battery is fresh, maybe I have the solder problem metioned above. Thanks for the input.
Old 11-23-2007, 03:14 PM
Auswak's Avatar
Auswak
Auswak is offline
I had the same RKE Battery Low message.
Just yesterday the key would not lock the car.
Opened up the key to see what battery is needed to replace and I had the solder issue with the battery clamp.
Re-soldered and all is now working fine
Quick Reply: RKE Battery Low
