Removal of Spark Plug Tubes
Old 02-19-2007, 09:01 PM
bassace3's Avatar
bassace3
bassace3 is offline
Default Removal of Spark Plug Tubes
I have a bit of a problem. I've got a 95 Neon and it blew a plug. I've purchased a helicoil repair kit. I've removed the valve cover and now need to how to remove the spark plug tube or even if it's possible to do so. Can anyone help a very VERY green shade tree mechanic out?
[IMG]local://upfiles/56455/C020482A9C514E6B962AD48CC78BFC21.jpg[/IMG]
Old 02-19-2007, 09:21 PM
HabitatHxC's Avatar
HabitatHxC
HabitatHxC is offline
Default RE: Removal of Spark Plug Tubes
I think its an interferance fit, So you have to pull really really hard and it should come off.
Old 02-19-2007, 11:33 PM
bassace3's Avatar
bassace3
bassace3 is offline
Just pulling it off without turning or twisting? Ok, will try that.
Old 02-20-2007, 12:36 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
you can actually insert a heli-coil by removing only the spark plug and wire....
i had to put one in my car a couple monthes ago....
take the tap and load it up with grease.....then after you've tapped the hole, start up the car without the spark plug in it....that way it can blow all the old shavings out of the hole....then insert the heli-coil...
worked great for me
Quick Reply: Removal of Spark Plug Tubes
