03 ram defrost, vent , floor hvac problems
Old 02-15-2007, 02:38 PM
camaroboy8691's Avatar
camaroboy8691
camaroboy8691 is offline
Default 03 ram defrost, vent , floor hvac problems
hey guys , im new to this furom , and also new to dodge stuff , i just bought my first 03 ram 2500 quad cab with a ctd last week
id take is back to the dealer where i got it but hes in illinois and im in pa sooo here i am stuck
when i have the vent **** on one setting it may take a few minutes before it goes there , sometimes i can have it on defrost and it will only go to the floor vents no matter where the **** is , sometimes i can put it on defrost and it will go right there , sometimes i can put it on dash vents and it will go right away and same with floor vents
its just really wierd , i asked a few guys on this drag race furom i go on everyday and a few said it may be the blend air door , it just seems wierd and makes me think it may be the actual control **** that is fualty
anyone came across this yet?
thanks ted
Old 02-15-2007, 03:01 PM
BigNelly07's Avatar
BigNelly07
BigNelly07 is offline
Default RE: 03 ram defrost, vent , floor hvac problems
sounds like a vacuum problem, since thats how most of the manual climate controls work.
Old 02-15-2007, 03:30 PM
camaroboy8691
thats what i tought vacumm being a chevy guy i wouldnt even ask this quesion
but being new to the dodge family i was told on this model with the cummins it does not have vacumm it is all electrical , i had the center dash off already to put a radio in it and the plug that goes into the back of the control unit looks fine
its just hard to belive that a truck with only 61,000 is having this wierd problem
here is a link to a repair guide a guy gave me http://home.hot.rr.com/jlnun/BLEND.htm it tells how the system works it just seems like a servo or the control panel ****
Old 02-15-2007, 03:34 PM
BigNelly07's Avatar
BigNelly07
the issue I am having trouble with is that you say it sometimes works and sometimes dont. So its either a short or sticking....
Old 02-15-2007, 08:05 PM
camaroboy8691
ok i went out for a drive in the truck today , here is what it did
had it on defrost and floor , it was working great coming out both places , i turned the **** to dash vents only and air came right out no where else , had it on that position for a bit , then moved it to the floor only and it wnet there right away , figured ok must be my lucky day , turned it to defrost only and it didnt do anything
im just trying to see if anyone else had this problem before i take the dash out and the hvac to see whats up
Old 11-06-2007, 07:04 PM
rcockels's Avatar
rcockels
rcockels is offline
Here is an actual web site that shows the fix.There is a Bulletin on this issue.http://dodgeram.info/tsb/2002/24-004-02.htmI had the same problem, no defrost or floor air. Graually it worsens untill all you get is air only out of the bi-level, no matter what heating/AC setting you choose from the control ****. The fix was replacing the Panel Door Actuator and the Blend Door. This was all done without removing the HVAC!!! Yes, there were some removal of Dash and Glove box, but not to the extent of REMOVAL of the Whole Dash and HVAC Assembly. I walked out the door for $569.00 The actual problem on my truck was the plastic housing on the blend doorwhich became stripped and the panel door actuator could not turn the blend door any longer in any position.
Old 11-06-2007, 07:20 PM
rcockels's Avatar
rcockels
rcockels is offline
The Pencil is pointing at the WHITE PLASTIC BLEND DOOR HOUSINGIS WHICH TURNS THE BLEND DOOR
[hr]
Bingo, that was my problem. the Blend door themselves are in great shape, no cracks but the plastic housing is stripped! Save your paper work cause if Dodge does get a class action suit in a few years from now, you will have the paper work.
2004 Dodge Ram 2500
Old 12-01-2007, 12:34 AM
willyfish's Avatar
willyfish
willyfish is offline
Not to be stupid but what did you need to replace the actuator?
Old 12-01-2007, 04:17 AM
abarmby's Avatar
abarmby
abarmby is offline
ORIGINAL: rcockels
Hi, Are you saying it cost you $569 for the actuator and blend door???
Al.
Old 12-01-2007, 10:31 AM
speeddemon145's Avatar
speeddemon145
speeddemon145 is offline
my 04 1500 the blend door broke off at 40 k miles. so I pulled the blower motor and reached up inside and removed the broken door through the hole for the fan. now ac is working ok but not as cold becouse pulling air from inside cab and outside air at same time.
Quick Reply: 03 ram defrost, vent , floor hvac problems
