Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Dual cold air intakes
Old 02-08-2007, 07:07 PM
trill's Avatar
trill
trill is offline
Default Dual cold air intakes
I've been noticing the price difference between the dual cold air intakes on EBAY and the normal pricing. Does anybody know if these cheap dual intakes work or would I be better off paying the plus or minus $300 for a CAI?
Old 02-11-2007, 02:00 AM
superdak05's Avatar
superdak05
superdak05 is offline
Default RE: Dual cold air intakes
no, because the dual intakes sit right above the exhaust manifolds sucking in only hot air. anything that claims to be a cai that doesnt have a heat shield isnt. i got my intake off ebay for 212.00
Old 04-29-2007, 04:26 PM
Candakota02's Avatar
Candakota02
Candakota02 is offline
So you're saying if I can find a dual with the heat shields on the filter I will be OK????
Old 05-07-2007, 04:48 AM
98R/TDak's Avatar
98R/TDak
98R/TDak is offline
that or what i heard what someone else did is they got extra tubing and directed them to the wheel wells on each side and then wrapped the tubing from the intake all the way to the filter with heat wrap...it takes some handy man modding but if its done right i think it'd work pretty good
Old 05-07-2007, 04:13 PM
red9535's Avatar
red9535
red9535 is offline
Dual intakes won't help you any more then a single intake.. you can still only take in 14.7 PSIyou should get a supercharger if you want more then that.. the only reason to get dual cold air intake would be for some under the hood bling.. if you are going for performance , do what someone else said and run your intake down by your fender where the air is actually cold
Old 05-08-2007, 04:23 PM
07Ramjam's Avatar
07Ramjam
07Ramjam is offline
I saw the same thing on Ebay.Like everyone else CAI's for the most part are not worth it.However,for 50.00 the dual intake does look very cool.Id buy it just for the bling factor.
Old 05-21-2007, 08:18 PM
chubyboy's Avatar
chubyboy
chubyboy is offline
why not just put in ram air? im looking to do it, and if ur like me, with very little $$, i would think vinyl dryer duct would do just fine...
Old 05-23-2007, 08:39 PM
chris1974's Avatar
chris1974
chris1974 is offline
ORIGINAL: chubyboy
Here's the deal with ram air.....
Unless you are going to be doing over 135 mph, you are not going to get any performance gain from adding ram air. Like Red said, the throttle body can only flow 14.7 psi. In order for the TB to flow more air than that, you would have to be doing at least 135, or get a supercharger that will ram the air into the motor. Ram might look cool....but your not going to see any performance gains at all.
Old 06-06-2007, 12:43 AM
shadowestwin's Avatar
shadowestwin
shadowestwin is offline
Original:98R/TDak
Now I know that the air inthe wheel wells are cool but isnt the air pressure incredibly poor? and if the air pressure is low thenisnt that countering the modified intake?
Old 06-06-2007, 12:35 PM
chris1974's Avatar
chris1974
Air pressure is poor, but pressure is not what you are after with a cold air intake. Your after less constriction. The stock air set-up isn't bad, but none the less, it is more restrictive than a "cold" air intake. There are bends, and dead ends where the air loses its flow velocity. Adding aCAI isamuch less restrictivepath, so faster throttle response is what is achieved. And of course- cooler air. Cooler air = more power.
Quick Reply: Dual cold air intakes
