My Neon Leaks Oil
Old 08-17-2004, 02:09 PM
ZoomNeon's Avatar
ZoomNeon
ZoomNeon is offline
Default My Neon Leaks Oil
The Neon has been leaking oil now for about a year. It's a very slow leak, about a quart every 6-8 weeks. Typically what I do is top it off when it is down 1/2 quart and change the oil every 3,500-4,000 miles. I'm not gonna get the leak fixed because it was quoted at $600. I don't know much about repair but I do change the oil myself. I wouldn't be able to fix it myself. I am gonna drive the thing until it breaks down and then buy a new car. Anyone have any advice and how to keep this one running as long as possible? What brand of oil and filter should I use? Should I try that 'stop oil leak' additive? Should I be changing my oil more frequently because of the leak? Thanks.
Old 08-17-2004, 02:17 PM
dustyloins's Avatar
dustyloins
dustyloins is offline
Hall of Fame Member
Location: Alamosa, Colorado (200 yards from the Rio Grande)
Default RE: My Neon Leaks Oil
Many older Neons leak oil. It's a head gasket issue. A new one should fix your problem, but since you don't want to spend the $$, you can continue to add oil as needed. If the leak gets any worse, I'd think again about getting it repaired. Stay away from those "stop leak" additives, they'll just gunk up your engine.
Old 08-17-2004, 02:35 PM
verhagem's Avatar
verhagem
verhagem is offline
Deleted by user.
Old 08-17-2004, 03:28 PM
ZoomNeon's Avatar
ZoomNeon
ZoomNeon is offline
Thanks for the advise guys. I figured it was the head gasket, I've have heard that from others as well. Any advice on what brand/type of oil or filter to use?
Old 08-17-2004, 03:49 PM
moparturd's Avatar
moparturd
moparturd is offline
The camshaft seals are also known to leak alot.
Old 08-17-2004, 03:52 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Since you're leaking oil, it's going to cost you major $$ if you switch to synthetic. Stick with a good quality dino oil and a NAPA Gold oil filter.
Old 08-17-2004, 04:54 PM
moparturd's Avatar
moparturd
My first neon had a .5 qt/3K mi. leak. When I swithched to synthetic it doubled.
Old 08-18-2004, 02:09 PM
Altima_wb's Avatar
Altima_wb
Altima_wb is offline
ORIGINAL: dustyloins
I like seeing that. I work at NAPA and use nothing but.
Quick Reply: My Neon Leaks Oil
