Clicking sound......
Old 02-07-2007, 09:11 PM
junkman306's Avatar
junkman306
junkman306 is offline
Default Clicking sound......
on my 94 ram 1500 318. It's a clicking or ticking sound similar to a lifter tapping except it it's coming from the intake mani on the passenger side right near the injectors. Could it be a bad injector?
Old 02-07-2007, 09:26 PM
topsites's Avatar
topsites
topsites is offline
Default RE: Clicking sound......
I think it's more likely to be an exhaust manifold air leak.
Although most exhaust leaks sound like a deep throaty rumble, if the leak is up in the front at the manifold, it will sound metallic, high pitched, almost like someone banging on your engine block with a steel wrench, sorta.
Anyway, that or it could also be something to do with that stupid exhaust air injector, if Chrysler still puts that crap on cars, back in the old days it was sometimes referred to as the smog pump, the air pump, the smog air injector, etc.
Old 02-07-2007, 09:27 PM
ShakyJay's Avatar
ShakyJay
ShakyJay is offline
Very well could be that. I had a similar noise that occurred when truck warmed up and was under load at about 45-50 mph. I thought it sounded more likean exhaust leak kinda of a tick tick tick noise or even a bad plug wire. Could not hear at idle. Eventually the dealerfigured out it was a bad intake gasket. Of course that was after months of complaining and only after the truck went out of warranty. Go figure.
Old 02-07-2007, 09:28 PM
Ramdamit98's Avatar
Ramdamit98
Ramdamit98 is offline
My PCV valve rattles sometimes and sounds like lifter noise.
Old 02-07-2007, 09:44 PM
Sirhilton17's Avatar
Sirhilton17
Sirhilton17 is offline
Mine makes the same noise, its PCV...
Grab the PCV valve real tight and it goes away.
Old 02-07-2007, 10:37 PM
junkman306's Avatar
junkman306
It only notice it at idle when im looking under the hood. It's on the passenger and it sounds like its coming from the injector area. And thats with me ear right by it not just standing there guessing. I just put a new pcv valve in and it's tighter than a ticks butt so I don't think thats it.
Old 02-08-2007, 07:35 AM
Ramdamit98's Avatar
Ramdamit98
The internal restrictor (generally a cone or ball) inside the PCV Valve is what makes the clicking sound. The vacuum pressure at idle likes to rattle that little ball around on mine.
Old 02-13-2007, 08:36 PM
junkman306's Avatar
junkman306
Well i guess that could be it, but it's repetitive. It clicks in time like an injector or something.
Old 02-14-2007, 01:26 AM
Ramdamit98's Avatar
Ramdamit98
I know when I first heard mine clicking I thought it was the lifters. You could pull the hose that goes to the PVC valve off the intake while it's running and remove the vacuum on the PVC valve and see if the clicking stops. If it stops then you know it's the PVC valve, it not then at least you know that.
I've heard that Marvel Mystery Oil is good for quieting noisy lifters.
Old 02-16-2007, 03:46 PM
junkman306's Avatar
junkman306
I'll give that a whirl and see what happens.
Quick Reply: Clicking sound......
