How To - 2005 Caravan sway bar bushing replacement
Old 02-05-2007, 06:21 PM
LSUfan71's Avatar
LSUfan71
LSUfan71 is offline
Default How To - 2005 Caravan sway bar bushing replacement
I've read enough here and other places to figure out that I need to replace the sway bar bushings on my '05 Caravan.A photo of this mysterious little object or maybe even a diagram would be nice, if such a thing exists on the web. Are any links available? I understand that I should be able to accomplish this DIY projectin my carport or would any of you advise against this for a novice? I can replace shocks and brake pads so I'm not completely void of mechanical knowledge (but almost).
Old 02-05-2007, 08:16 PM
mazdab2600's Avatar
mazdab2600
mazdab2600 is offline
Default RE: How To - 2005 Caravan sway bar bushing replacement
here's some pic's
http://images.wrenchead.com/smartpag.../K7258_TOP.jpg
and the parts the same # for 96-05 for moog k7258
http://www.autozone.com/servlet/UiBr...3d801a4ace.jsp
Old 02-05-2007, 09:33 PM
LSUfan71's Avatar
LSUfan71
LSUfan71 is offline
Awesome, thanks a bunch.
Old 02-08-2007, 08:01 PM
LSUfan71's Avatar
LSUfan71
LSUfan71 is offline
UPDATE
Just finished the job. It was definitely the sway bar bushings. The van rides quiet and soft again.
Old 01-08-2008, 08:02 PM
LSUfan71's Avatar
LSUfan71
LSUfan71 is offline
ORIGINAL: LSUfan71
UPDATE
A little over 10 months later and the darn things need to be replaced again.
Old 01-09-2008, 08:44 AM
LSUfan71's Avatar
LSUfan71
LSUfan71 is offline
ORIGINAL: LSUfan71
Are the black rubber ones the only thing available or is there something better?
Old 01-25-2008, 06:12 PM
holtzer1's Avatar
holtzer1
holtzer1 is offline
you can get blue silicone bushings from moog. get the MOOG PROBLEM SOLVERS...not the low end moog line. they might last a year.
what it boils down to is this is a design flaw...theres way too much pressure put on the sway bar bushings, theres nothing you can do about it except get used to the clunk, or have tools handy and replace em often.
Old 01-26-2008, 10:36 PM
ghlkal's Avatar
ghlkal
ghlkal is offline
ORIGINAL: holtzer1
Is this a problem with the '06 model also? (I assume that 05-07 are the same ...)
Gary
Old 01-26-2008, 11:41 PM
onephatcracka's Avatar
onephatcracka
onephatcracka is offline
if it's just the bushings.. what you can do to make them last a little longer is bend the brackets holding them on a very small amount to make them a little tighter. Are you sure its not the endlinks that went out this time? have someone rock the van while holding the link and see if there is any movement. (there are greasable ones out there... not sure how longevity plays in though)
those are a pretty regular thing that needs replaced to get rid of that annoying clunk noise.
Old 01-28-2008, 08:02 AM
HankL's Avatar
HankL
HankL is offline
My 70 year old parents have been complaining of noises in the front suspensions of their 2001 and 2005 Town and Country vans. I just drove them 1200 miles over the last two days and it does seem to be the sway bar bushings on the 2005, on a vehicle with less than 50,000 miles. Chrysler ought to treat its customers right and issue a recall on those bushings, or at least a 'customer satisfaction' warranty extention.
Quick Reply: How To - 2005 Caravan sway bar bushing replacement
