How many miles do you have on your truck!
  #111
Old 07-02-2007, 02:45 PM
Dark_Horse's Avatar
Dark_Horse
Dark_Horse is offline
Default RE: How many miles do you have on your truck!
Got 158,000 on my 96 318 5 speed
Problems so far are:
New shocks
Replaced water pump
Replaced upper/lower/bypass hoses
Replaced thermostat
Clogged cat - replaced
Hole in muffler - replaced
ECU reflash to get rid of annoying backfire CEL which would cause truck to stall when at a stop
Paint is peeling off of passenger side door & hood. No point in fixing this at the moment.
  #112
Old 07-02-2007, 05:35 PM
RamManRiley's Avatar
RamManRiley
RamManRiley is offline
200,578 as of today. only thing major was trans bout 20k ago.
  #113
Old 07-02-2007, 06:07 PM
2001dodgeram1500's Avatar
2001dodgeram1500
2001dodgeram1500 is offline
well, i bought my truck with about 61,000 miles on it 9 months agoand it now has 67,570 miles as of today
and i have replaced front u-joints,IAC, cap an rotor , clogged cat, and just basic maintenence
but if you search posts by ME you will find i am having issues with it dying when it warms
to opperating tempature. tomorrow i get to install another part (IAT)and see if that helps.
if you are wondering why such low miles after 9 months
i live 1.2 miles from work and my wifes durango is the vehicle we use when we go places.
  #114
Old 07-02-2007, 11:48 PM
Pyromanaron's Avatar
Pyromanaron
Pyromanaron is offline
180k, pullin 5 ton spreader buggies through sticky wet fields. Nothing major wrong
  #115
Old 07-03-2007, 06:30 AM
n1rigger9's Avatar
n1rigger9
n1rigger9 is offline
WOW, my "97 only has 70,000 and no problems yet. WOOOHOOO, I guess its a keeper and the value has to be higher than normal. LOL
  #116
Old 07-03-2007, 06:43 AM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
101,000 on mine.
Replaced the water pump around 98k
Fuel pressure valve 98k
Other than that good to go.
  #117
Old 07-03-2007, 03:01 PM
Rammin97's Avatar
Rammin97
Rammin97 is offline
Tranny at 37,000. Yes, just after warranty ran out. No major failures since. 127,000
  #118
Old 07-03-2007, 03:30 PM
Rjerred1's Avatar
Rjerred1
Rjerred1 is offline
1999 dodge 1500 sport with 92,000 miles on it. The motor blew up after only owning this pick up for 2 and a half months, i still want to go ahead and rebuild the motor because i feel like im driving a 20,000 pick up and its great to take around town.
  #119
Old 05-20-2009, 03:40 AM
crazydavey69's Avatar
crazydavey69
crazydavey69 is offline
1998 Dodge Ram 1500 SLT Laramie quad cab 4x4.....
Bought with 140k on it a few years back.... then had to have pretty much the whole passenger side replaced thanks to someone running a red light.(ever seen a full size truck spinning around in the air?) That accident caused the IAC to go bad. Rearend was also replaced due to that. Then I had to replace the water pump and drivers side wheel cylinder a couple years ago. Shortly after that my speed sensor stopped working..... So still showing 199k on the odometer Actual is well over 310k now. Replaced the fuel pump about a year ago. Eight months ago my cat plugged up tight, so replaced that with an off road unit(no cat). And two days ago I replaced the passenger side wheel cylinder. Front axle u joints are next week!
  #120
Old 05-20-2009, 05:29 AM
iwhitne's Avatar
iwhitne
iwhitne is offline
I bought mine a year ago with 83,xxx... it was incorrect due to a tranny re-build... since then I have 142,576 on her.. I did a car fax and the vin came back to last recorded service with 170,000!! sooo...142,576-83,000= 59,576 + 170,000= 229,576
Quick Reply: How many miles do you have on your truck!
