Diagnostic Trouble Codes FULL List
Old 02-08-2012, 10:31 AM
mjluneack's Avatar
mjluneack
mjluneack is offline
I have an intermittent P2097. Don't see that listed. Seems to come on after cruising at freeway speed for some length of time. Doesn't come on with every long trip and will clear itself after a few key cycles. Any ideas for the cause?
Old 02-08-2012, 02:57 PM
DESERTRAT8's Avatar
DESERTRAT8
DESERTRAT8 is offline
Default Codes
SOME OF THESE CODES REFER TO GM?
CONVERTED THIS TO PDF
File Type: pdf
Old 02-09-2012, 02:29 PM
DESERTRAT8's Avatar
DESERTRAT8
Sorry i also checked the service manual no help
Old 04-17-2012, 09:06 PM
bigdog3030's Avatar
bigdog3030
bigdog3030 is offline
2006 dodge 250o cummins 5.9 with codes p1750 and p1755
Old 04-17-2012, 09:18 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
The P1755 is listed on the first page...
P1755 Intermediate Speed Sensor (ISS) Malfunction
The other can easily be google'd:
P1750 Solenoid Assembly Malfunction http://www.aboutautomobile.com/DTC/P1750 "Solenoid Assembly Malfunction"
Old 12-23-2012, 10:27 AM
inksmith's Avatar
inksmith
inksmith is offline
yeah, well has anyone heard of a P09E0? had that and a P0100 pop up on my Bully Dog.
Old 01-13-2013, 05:22 PM
agoodreedindeed's Avatar
agoodreedindeed
agoodreedindeed is offline
i have some codes that came up on my truck but arent on here, i have a 2005 dodge ram 3500 5.9L these are all the codes i got... 0205, 0336,0643, 0868, 0108, 0069 anyone know what 0069, 0643, and 0868 are? my mechanic isn't open today ;0)
Old 02-02-2013, 01:41 PM
roadtech's Avatar
roadtech
roadtech is offline
New Member
Default 2006 dodge fuel problem
hey guys, I think I got bad fuel in WA, Friday,, running hard to Oregon,
check light comes on, scan codes, p088,p0148,p0251
tested rail pressure with a buds no change, I unplug FCA and nothing changes on truck,, rough idle, falls on face at 2200 rpm some sort of fuel issue,
changed fuel filter and added additive for water,
Old 02-02-2013, 01:42 PM
roadtech's Avatar
roadtech
roadtech is offline
New Member
oops 2006 dodge ram 2500 5.9
Old 03-04-2013, 03:57 PM
freddmc's Avatar
freddmc
freddmc is offline
Default No Error Codes
I have a new(to me) 2005 Ram cummins dually and decided to look to see if there were any error codes displayed. So I did the key sequence to bring up the codes and the mileage display went from mileage to 5(or 6) dashes for a number of seconds and then eventually went back to displaying the mileage. Also after about 30 seconds the "engine" symbol appeared on the display.
Does this indicate no errors found?
Thanks
Fred
Quick Reply: Diagnostic Trouble Codes FULL List
