Temp gauge doesn't work
Old 01-11-2007, 02:10 PM
89 dakota's Avatar
89 dakota
89 dakota is offline
Default Temp gauge doesn't work
What might be the problem? Thermostat? Gauge itself? The temp gauge in this truck has never worked and i would like for it to work properly. It REALLY bothers me that it doesn't work.
Old 01-11-2007, 03:44 PM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
Default RE: Temp gauge doesn't work
it's probly your coolant temp sensor. you will have 2 of them. the one on the front of the engine by the rad hose is for your computer to sense when your motor is warmed up. and the one near the back of the engine will be for your guage. I would try that one. it could either be the sensor it's self or a loose wire. if it's not that, then it's yor guage. but I bet its just your sensor.
mine doesnt work either, but aslong as I get heat. I'm not too worried about it
Old 01-11-2007, 03:46 PM
Mr_Shorty's Avatar
Mr_Shorty
Mr_Shorty is offline
try grounding out the signal wire from the sender unit. If the sender is bad, but the gauge works it will peg the needle.
Later Daze,
Shorty
Old 01-11-2007, 04:03 PM
89 dakota's Avatar
89 dakota
ORIGINAL: jonnymagnum
could you post a pic of where it is in the engine bay. In my haynes manual it only shows the front one.
Old 01-11-2007, 11:51 PM
dodgerules86's Avatar
dodgerules86
dodgerules86 is offline
Like jonnymagnum said, you do have two coolant temperature sensors (one for the gauge, one for the computer). However, all the information I have places both temperature sensors at the front of the motor. The one for the computer is to the left (drivers side) of the upper coolant hose, while the one for the gauge is to the right (passengers side) of the upper coolant hose. The one for the computer is a two-wire connector, while the one of the gauge only have 1 wire running to it (and is typically violet).
Old 01-15-2007, 04:37 PM
89 dakota's Avatar
89 dakota
O.K..... so i found the sending unit but how do I get it out? I can barley get my hand in there. In my manual it says just to unscrew it but it seems like you have to take the wire off first right? I don't wanna wreck anything.
Old 01-15-2007, 04:40 PM
jonnymagnum
ya, take the wire off first and soak the threads in penentrating fluid and let sit for a couple minutes. then try to take it out. since it's probly the original one. it will be stuck in there good.
doomofa91 (04-18-2022)
Old 01-17-2007, 06:45 PM
89 dakota's Avatar
89 dakota
How the hell do I get the sending unit out!!? The only way I got the wire off was with a long pair of needle nose pliers. I can't get my hand in there and I don't wanna wreck the old sending unit. I know there has to be a way to do this obviously, I'm just not seeing it.
Please help
Old 01-18-2007, 05:39 AM
dodgerules86
ORIGINAL: 89 dakota
Please help
IIRC, I used a flat-tip screw driver to undo the electrical connector. Than, I used a deep socket (around size 13 I think) to get the actual sensor out of the block. Its a little tricky to keep the sensor in the socket to clear everything thats in that area (coolant hose, alternator, and everything else), but is definitly do-able.
I know, its not the easiest thing in the world, but I can think of things a lot worse.
Old 11-16-2022, 12:29 PM
Hitec's Avatar
Hitec
Hitec is offline
Default Temperature Guage doesn't work
I had the same problem. What I did was to take the serpentine belt off the alternator, removed the bolts from the alternator, (might have to remove the bolt holding the dipstick), after I got the alternator free from the bracket I rotated the alternator clockwise exposing the sensor.
The ac line ac lines make it a pain but it can be done.
An alternative way is to un mount the ac compressor (you don't have to break any lines a loose.) And moove it out the way. Loosen the bottom bolt on the alternator and take the top alternator bolt out. Just swing tha alternator to the side and you wull have access to both sensors
Hope this helps
Quick Reply: Temp gauge doesn't work
