How do I remove my Clutch Fan???? Whats the trick?
Old 01-09-2007, 04:20 PM
93 V8 Dakota 4x4's Avatar
93 V8 Dakota 4x4
93 V8 Dakota 4x4 is offline
Default How do I remove my Clutch Fan???? Whats the trick?
Ok guys, I'm fixing the water pump gasket on my other truck it has the 3.9 V6. I have done this before but can remember the trick. How you hold the water pump pulley from spinning while taking off that large nut that holds the fan on?
I looked in my repair book (Haynes I think) and it was very vague..... no help there.
I also have been googing all day and found nothing either? I didn't remember this being that hard? Any suggestions would be great.
Old 01-09-2007, 06:29 PM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
Default RE: How do I remove my Clutch Fan???? Whats the trick?
I would try jamming something in between the fan blades and see if that helps.
or if you have one of them strap wrenches, I dont know what there called. but then you can wrap it around the pully to hold it inplace.
Old 01-09-2007, 07:09 PM
BAnders's Avatar
BAnders
BAnders is offline
you need to wedge a large screw driver or prybar between the pulley bolts while you turn the wrench, check out 3-5 of the haynes book
Old 01-09-2007, 07:52 PM
93 V8 Dakota 4x4
The Haynes book is actually what I have.... that won't work because there are no bolts on the pulley. The bolts that hold the fan on are on the clutch which spins freely from the pulley. The pully has holes in it but you can't really wedge any thing in them because the holes are blocked by the clutch. I'd post a picture but I won't be by a computer later. I'm going to tackle it after work, I liked the strap wrench idea. Thanks again guys.
Old 01-09-2007, 10:12 PM
Chris's Avatar
Chris
Chris is offline
Hold the fan with our hand and hit it with an air wrench.
Old 01-17-2007, 07:06 AM
the dakota's Avatar
the dakota
the dakota is offline
if it is a bolt on pully like mine i just took the 4 bolts out of the pully an clamped some visegrips on the pully to get the bolt off hope this helps the dakota
Old 01-17-2007, 07:14 AM
Mr_Shorty's Avatar
Mr_Shorty
Mr_Shorty is offline
I removed the four bolts holding the assembly to themotor and then held the clutch in my hand while turning the nuts with a wrench.
Quick Reply: How do I remove my Clutch Fan???? Whats the trick?
