which antifreeze do I use in a 2002 Ram 1500 4.7L
Old 01-09-2007, 04:07 PM
hdvespa's Avatar
hdvespa
hdvespa is offline
Default which antifreeze do I use in a 2002 Ram 1500 4.7L
OK guys, which antifreeze can I use in my 2002 Ram 1500 4.7L engine. The manual says to use Ethylene Glycol with corrosion inhibitors called HOAT. So do I use the old green stuff? what is the orange stuff sold at the stores?
Old 01-09-2007, 10:59 PM
GSXR1181's Avatar
GSXR1181
GSXR1181 is offline
Default RE: which antifreeze do I use in a 2002 Ram 1500 4.7L
I use Prestone DEX-COOL in everything I own. My truck, car, bike, 4 wheeler's, and even to winterize my jetski. Yes thats the orange stuff.
Old 01-10-2007, 02:53 AM
reiderr's Avatar
reiderr
reiderr is offline
I strongly suggest you do NOT use Dex-Cool. It is not approved for DC vehicles. Instead, use, in decending preference, MOPAR, Zerex G05 Formula (Gold container), various long-life coolants such as Prestone, Peak, etc. that are NOT Dex-Cool clones. Also, if you don't use MOPAR, then try to flush out as much of the old coolant as possible with at least 3 or more drain, fill, runs (at least 15 minutes of driving) cycles using ONLY distilled water. If you use the MOPAR coolant, just drain the radiator and refill unless you can see obvious contamination. Then do the flush cycles as above.
Roger...
Old 01-18-2007, 06:30 AM
blakusta's Avatar
blakusta
blakusta is offline
You aren't supposed to use the green stuff, I just changed mine and put in some kind ofextra long lasting stuff
Quick Reply: which antifreeze do I use in a 2002 Ram 1500 4.7L
