Drew: How about a DIY on the rear Diff??
Old 12-22-2006, 09:27 PM
Cactus Jack's Avatar
Cactus Jack
Cactus Jack is offline
Default Drew: How about a DIY on the rear Diff??
Drew,
Your DIY on the fuel flter was great. How about a DIY on changing the rear diff. fluid? Do you use Royal purple?
Old 12-22-2006, 10:15 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
Default RE: Drew: How about a DIY on the rear Diff??
thediff fluids can be changed 1 of 2 ways, pump it out or pull the diff cover.
if you pull the cover,
1) Put oil catch pan under the diff housing
2) Untorque all of the diff bolts and loosen them so that oil can escape from the diff
3) drain diff until most of it has been removed, then remove the cover
4) clean the mating surfaces really well so there is no silicon sealant on it and the housing.
5) make sure both surfaces are free of oil and are clean and dry.
6) wipe out the bottom of the diff housing to get any gunk out that may be there.
7) apply sealant(black or orange silicone gasket maker works fine)to the diff cover, replace the cover and hand tighten all the bolts back into the housing.
8) using a torque wrench tighten every other bolt to 30 ft lbs of torque until all of them are tight. I would recommend doing it in a couple of steps, maybe 15 lbs all the way around, then the 30 ft lbs.
9)pop out the fill plug (rubber) andrefill with your favorite 75w-90 fluid (amsoil or redline are good choices... also mobil 1) or if your towing heavy, use a heavier oil. the shop manual specs 75w-90
I recommend using a pump to fill the diff, makes it easier than trying to pour fluid in.
I also would recommend gettinga marine oil change pump to vacuum out the diffs if you dont want to pull the covers.
Hope this helps...
[IMG]local://upfiles/1508/E517E6C333884550A2C1CEFF3464ADBC.jpg[/IMG]
Old 12-22-2006, 11:03 PM
i11m10c2's Avatar
i11m10c2
i11m10c2 is offline
Shouldnt there be a step before #7 for the new sealant or better yet put a mag-hitech which alread has a o-ring seal.
Old 12-22-2006, 11:28 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
http://www.pavementsucks.com/tech/diff.php
Old 12-23-2006, 12:15 AM
steve05ram360
ORIGINAL: i11m10c2
yup, good catch...
Old 12-23-2006, 01:56 AM
jakebrake's Avatar
jakebrake
jakebrake is offline
if your talking about adding steps, I didn't see one that said stop off at the liquor storewhile picking up oil.
Old 12-23-2006, 05:07 AM
i11m10c2's Avatar
i11m10c2
i11m10c2 is offline
Yup i agree better get liquored up so that when you go to fill your tank it dont sting so bad,damb governor,i swear she wont be happy till we are all broke!![:@]
Old 12-23-2006, 05:14 AM
i11m10c2's Avatar
i11m10c2
i11m10c2 is offline
THANK YOU OH WISE ONE!![sm=bounceybounce.gif]
Old 12-23-2006, 06:33 PM
crazykidjj87's Avatar
crazykidjj87
crazykidjj87 is offline
i11 you must be from CT...if not then in CT we have a bitch govenor who loves fuel taxes and doesnt give a damn about us truck owners who have 34 gallon tanks. its all BS.
Old 12-24-2006, 12:47 AM
NickBeek's Avatar
NickBeek
NickBeek is offline
My rear diff has a reusable gasket behind the cover and the fill plug screwed in . I also remember reading somewhere that first change you should pull cover to inspect for loose or misfit "c" clips.
Quick Reply: Drew: How about a DIY on the rear Diff??
