Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Sponsored by:
Sponsored by: Mall of Georgia
96 RAM 3500 - Brake Controller wiring
Old 07-28-2004, 02:45 PM
jiaram's Avatar
jiaram
jiaram is offline
Default 96 RAM 3500 - Brake Controller wiring
I just bought a 96 model RAM 3500 with tow pckg. Can somebody tell my where do I have to look for the wiring to connect an electric brake controller ?
Old 07-28-2004, 05:40 PM
BULLDOG's Avatar
BULLDOG
BULLDOG is offline
Default RE: 96 RAM 3500 - Brake Controller wiring
Well take a look in the manual if you have one. I have a 2000, and my truck came with a pigtail that I could wire to the controller, and then plug into the factory harness. That connector (on my truck) is located up underneath the dash near the emergency brake lever, it is light blue. Hope this helps.
Old 07-28-2004, 07:11 PM
jiaram's Avatar
jiaram
jiaram is offline
Yeah, I had a Ford truck that came with that came with a similar set and a couple of relays, and explanation separate from the manual. I guess the previous owner installed everything but did not save the literature. I will look underneath the dash as you suggest. Thank you much. You wouldn't know of a website where they might have any written instructions, would you?
Old 07-28-2004, 08:45 PM
BULLDOG's Avatar
BULLDOG
BULLDOG is offline
Right off hand I do not, but these are reasonably simple to install. What I can do that is easy is: fax, scan, or take a picture of what I have here. It would make it super easy if you can confirm that you have the same set-up. i can send the ligature that came with my truck.
Mine also has the addition (factory) to use the brake monitoring system. So you don't have to slide the lever over every time you need to activate the breaks.
Let me know how I can help.
Old 07-29-2004, 07:06 PM
jiaram's Avatar
jiaram
jiaram is offline
I'm gonna try to work it out thru the brake controller manufacturer. I found some instructions but if I need a picture I'll bother you.
Thanks again for the exchange.
Quick Reply: 96 RAM 3500 - Brake Controller wiring
