replacing antifreeze in 02 ram 4.7L, what to use
Old 11-30-2006, 05:22 PM
hdvespa's Avatar
hdvespa
hdvespa is offline
Default replacing antifreeze in 02 ram 4.7L, what to use
As the subject states, I was planning on replacing the antifreeze in my 02 ram 4.7L. The stuff in the overflow bottle looks pinkish/ red in color. Does it matter what I replace the old fluid with. Can I use the good old green stuff or is the fluid special?
Old 11-30-2006, 09:08 PM
vwomein's Avatar
vwomein
vwomein is offline
Default RE: replacing antifreeze in 02 ram 4.7L, what to use
You can NOT mix the 2 kind of antifreeze, but if you empty & flush the system, you
can use any kind. The red is a long-life antifreeze. Its supposed to be good for about
100,000 miles. The green I think is supposed to be changed avery 60,000.
Old 11-30-2006, 09:25 PM
NYPANAMA42's Avatar
NYPANAMA42
NYPANAMA42 is offline
I would go to a Dodge Dealership, and purchase their Mopar stuff....Just to be on the safe side...
Old 11-30-2006, 11:47 PM
reiderr's Avatar
reiderr
reiderr is offline
I second "NYPANAMA42" recommendation. Flushing a system as big as you find on the Ram is likely to require you to buy gallons and gallons of distilled water. So the tendency is to use tap water. That's almost worse than leaving the factory fill alone. Your simplest solution is to do the typical drain and fill using the Mopar coolant with distilled water. Unless you have some kind of sludging or contamination, that's all you really need. Don't use tap water unless there's no other alternative.
If you just can't do the Mopar route, then drain the block and radiator. Fill with distilled water. Drive for 5 mi. Drain, refill with distilled water. Drive 5mi. Drain and then add enough pure antifreeze to equal 50% of the capacity--eg, 18 qts, fill with 9 of coolant. Then top of with the distilled water. That way the pure water remaining in the system won't over dilute your fill.
Roger...
Old 12-01-2006, 01:39 PM
osteodoc08's Avatar
osteodoc08
osteodoc08 is offline
The Mopar coolant is a long life HOA (high organic acid) coolant specially designed for aluminum. It is not interchangable with just any kind coolant. Make sure you get the right coolant and make sure you use DISTILLED WATER as mentioned. The tap water at your house has all kinds of exgtra stuff in it that can cause deposits on your cooling system. Unless you have been having problems, I suggest a drain and fill.
Old 12-01-2006, 02:49 PM
DBLR's Avatar
DBLR
DBLR is offline
Texaco has a long life 150,000 mile anti freeze that you can use and it's cheaper then buying Mopar from a dealership and it's just as good. Don't buy any kind that has Dex Cool in it as it can play hell on your cooling system. If you can use Distilled water or buy your anti freeze pre mixed. The main reason to use Distilled is that many places in the USA the water has a high mineral content and these can cause deposits that can plug up your radiator.
Old 06-17-2012, 07:49 PM
hadams's Avatar
hadams
hadams is offline
New Member
Default 4.7 cooling - purple ice
I tow a trailer during the summer in the Rockies and occasionally my cooling temperature hits the limit. My son runs heavy duty equipment in the summer and recommends to use a water/Purple Ice mixture to reduce cooling temperatures about 30 degrees. Any pros or cons out there?
Old 06-17-2012, 10:09 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
There is another coolant out that is a bit cheaper then the dealer stuff, but is the same HOAT stuff. It's called Zerex G-05 and is available at Napa. It may be available at other places but Napa is the only place in my area to get it.
Old 06-17-2012, 11:41 PM
04HemiGreg's Avatar
04HemiGreg
04HemiGreg is offline
I use the zerex stuff that is approved for late model chrysler products, among others. And at less than a dollar a gallon for distilled water at any wally world and most grocery stores, i dont see why anyone should be tempted to dillute with tap water. Or just buy pre-dilluted anti-freeze. If you dont do a proper drain and flush, you would probably leave half the old stuff in there anyway. Do it right or dont bother. It is also a good time to change hoses and swap out the thermostat.
Old 06-18-2012, 05:52 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I have been using Prestone in mine for years and never any issues. Just flush good and refill.
Quick Reply: replacing antifreeze in 02 ram 4.7L, what to use
