2006 Ram 2500 Engine Block Heater cord plugin
Old 11-29-2006, 06:50 PM
joepuente's Avatar
joepuente
joepuente is offline
Default 2006 Ram 2500 Engine Block Heater cord plugin
HELP! I can not find where to plug in the cord in the engine block heater. Does anyone know where it is? [:@]
Old 11-29-2006, 07:05 PM
triton's Avatar
triton
triton is offline
Default RE: 2006 Ram 2500 Engine Block Heater cord plugin
ORIGINAL: joepuente
read the post above titled..... ( dumb question ) which it's actually not because you would think it was supplied at the factory.
Boy, anything to get another buck out of us!
Old 11-29-2006, 07:06 PM
triton's Avatar
triton
triton is offline
sorry...double posted.
Old 11-29-2006, 07:07 PM
joepuente's Avatar
joepuente
I know that you have to buy the cord, but it is where to plug it in that i can't find. The manual was NO help. Is it at all possible that my truck doesn't have a place to plug it in?
Old 11-29-2006, 07:10 PM
triton's Avatar
triton
triton is offline
ORIGINAL: joepuente
From what I've read.... all Cummins come with the block heater but, not necessarily the cord.
Look at the block right under the exhaust manifold just in front of the turbo. There a little boot covering the connector
Old 11-29-2006, 07:13 PM
cumminalong's Avatar
cumminalong
cumminalong is offline
Right behind the oil filter there is a black, plastic, screw on cap. That is the port.
The easiest way to get it on there is to remove the intake tube (2 screws) and then you have easy access to it. Otherwise you'll spend more time fiddling with it than you would have just removing the tube.
Old 11-30-2006, 04:03 AM
Dodge This's Avatar
Dodge This
Dodge This is offline
I had the same problem a while back. But like they said pull off the air tube to the turbo and look on the block you will see a black screw on cap. Its not that had to install and route to the front bumper so you can plug it in.
Old 12-01-2006, 01:46 PM
antano's Avatar
antano
antano is offline
hi.....rodrigo from costa rica
my truck has the plug on the passenger side, next to the radiator, and the intercooler.
hope it helps you
regads
rodrigo
Old 12-01-2006, 02:20 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Welcome aboard antano !!
[sm=welcomesign.gif]
Old 12-02-2006, 05:56 PM
Methos's Avatar
Methos
Methos is offline
ORIGINAL: cumminalong
Removing the intake tube doesn't really seem worth the trouble to me. I did mine about an hour ago from the bottom and was done in 3 mintes flat. Easiest thing I think I've ever installed
Quick Reply: 2006 Ram 2500 Engine Block Heater cord plugin
