I have reverse but no forward gears
Old 11-20-2006, 12:54 AM
jtridgerunner's Avatar
jtridgerunner
jtridgerunner is offline
Default I have reverse but no forward gears
I hope i am on the right Generation of Rams. I have a '75 dodge D100. 318, 4x4, auto. It is just a farm truck that rarely sees blacktop. A while back we drove it to the back field and shut it off to load fire wood into it. After setting for a half hour or soo, we started it back up and had no forwards gears. We tried shifting it into 4x4 hi and low with no change. Had to drive backwards all the way to the house then unloaded. The fliud seems fine. Right level, color, and good smell. Does ne one have ne suggestions. THe problem puzzles me because reverse is strong, but no 1st gear.
Old 11-20-2006, 04:28 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
dodgedakotacrazy is offline
Default RE: I have reverse but no forward gears
try adjusting the bands other than that i'd say your tranny is toast.
Old 07-12-2009, 10:58 AM
jtridgerunner
Found metal shavings in the pan. Cleaned the shavings out and slapped it back together and it goes strong again. Makes sense because when hte tranny is in reverse the fluild is flowing the opposite direction and not forcing the shavings to one area and stopping fluid travel.
Old 07-12-2009, 01:59 PM
SEAL's Avatar
SEAL
SEAL is offline
Couldn't be bands because low and reverse use the same band.
Quick Reply: I have reverse but no forward gears
