CHECK ENGINE LIGHT FLASHES 10 TIMES???
Old 11-09-2006, 01:46 PM
tbuster1002's Avatar
tbuster1002
tbuster1002 is offline
Default CHECK ENGINE LIGHT FLASHES 10 TIMES???
06 DCT 3500 auto trans., check engine light flashes 10 times and then stays on. Anyone seen this yet?
I don't want to use the dealer unless absolutely ness. any way to run diags without the dealer. Not exactly up to date on the 06 and 07 DTC yet.
Thanks!!
Old 11-09-2006, 02:57 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default RE: CHECK ENGINE LIGHT FLASHES 10 TIMES???
Can you at least call the dealer for a possible answer without taking it in?
Old 11-09-2006, 07:51 PM
gtxpooch's Avatar
gtxpooch
gtxpooch is offline
Take it to Autozone, Checker whatever and have them read the codes to give you an idea what's the codes are.
Old 11-12-2006, 10:30 PM
tbuster1002
Fuel cap failure. Had a Dodge tech scan for a code, but no code. $15 for a new Dodge cap and done. Dodge does not make a locking fuel cap for the CTD, but they do for a 1500 gas. Thank you for the help.
Old 11-12-2006, 11:49 PM
gtxpooch's Avatar
gtxpooch
gtxpooch is offline
Fuel cap failure on a 06 already? Isn't that warrantied?
Quick Reply: CHECK ENGINE LIGHT FLASHES 10 TIMES???
