Where do you get Pink antifreeze ??
Old 10-31-2006, 07:04 PM
ronj's Avatar
ronj
ronj is offline
Default Where do you get Pink antifreeze ??
I noticed my coolant is down a little, and it's also pink. I haven't looked around too hard yet but the only pink anti freeze I see available is for RV and marine use........
'06 2500 Hemi
Old 10-31-2006, 08:30 PM
osteodoc08's Avatar
osteodoc08
osteodoc08 is offline
Default RE: Where do you get Pink antifreeze ??
If it is down just a touch, just top off with some distilled or R/O water. If it is a lot, you've got to figure out why it is low.
Old 10-31-2006, 08:56 PM
motorhead426's Avatar
motorhead426
motorhead426 is offline
Pink or Red coolant is fine. Any parts store sells multiple brands of the red coolant. As long as its not the green coolant you'll be ok.
Old 10-31-2006, 09:34 PM
NYPANAMA42's Avatar
NYPANAMA42
NYPANAMA42 is offline
You might want to check Mopar's Anti-freeze. I believe theirs is red/pink in color..
Old 10-31-2006, 10:22 PM
osteodoc08's Avatar
osteodoc08
It is a HOAT type antifreeze. Makesure what you use, if you don't use just the R/O or distilled water as I mentioned, is compatible with this type antifreeze.
Old 10-31-2006, 10:56 PM
reiderr's Avatar
reiderr
reiderr is offline
To be on the safe side, I'd just buy the Mopar coolant and mix it with distilled water. It's not that much more expensive than after market coolants and you don't have to worry about any compatibility problems. I've had good results with Zerex's G-05 type coolant which is specifically formulated for Chrysler specs--gold colored jug typically found at Napa and Pep Boys. Whatever you do, stay away from Dex-Cool. Even though it's orange, it's a different formula. I mistakenly used it and wound up having to replace a timing cover gasket and water pump that it eat away. Dex-Cool is OAT and Dodge is HOAT.
Roger...
Old 11-01-2006, 02:06 PM
nathanp's Avatar
nathanp
nathanp is offline
depends what kind of climate you are in, if it gets cold and freezes there id be carefull about how much water you add. You can get the pink coolant at any auto parts store. Its an extended life coolant. I use penzoil coolant. Comes in a black jug, alot cheaper then mopar stuff and its just as good, never gave me an problems
Quick Reply: Where do you get Pink antifreeze ??
