1995 trouble codes
My mileage dropped from 17 to 13 this last week and i was looking to possible reasons.
1st the wiring for the O2 sensor was melted onto the cat. One wire was actually touching the cat. I repaired the wire. but i don't know if i should just replace the sensor. the burnt wire is the one on the connection with the O2 sensor. If i replace the sensor i have no burnt wires.
i am describing that poorly, but i think you get the idea
i checked for trouble codes today
12
37
17
55
I had the battery off a while back when the alternator went nuts and killed the truck.
37 is a code for the tranny, on the 95 if you didn't get the trailer package you didn't get a temp sensor, so it is always there as is my understanding.
17 is a code for too hot or too cold. never got this one before. temp gauge in seems to work fine. no idea? ????
55 is end of codes
I have a 180 degree tstat in the truck would that cause the code? or do i have another problem?
let me know
i liked my 17mpg
not liking the 13
12
37
17
55
55 is end of codes
let me know
i liked my 17mpg
not liking the 13
Also your too cold code may be coming from a faulty coolant temp sensor. If it thinks the engine is running too cold, which would explain your code 17 it will dump fuel into your engine in an attempt to warm it back up and that would explain your drop in mileage. I would check the wiring on your coolant temp sensor, if it checks out ok them replace the sensor. If that doesn't fix it I would look too the thermostat being stuck open.
[IMG]local://upfiles/20323/9DF2E9C9AF4D45ADA5A3F9546C9AB6C4.jpg[/IMG]
The picture here I took off of RM_Indy's website, it shows you where the coolant sensor is located. It will be behind your alternator.
ORIGINAL: TPSDODGE
there are two temp units one is the sensor for the engine(behind the water neck) and the one for the guage (behind the alt)
Page 383 if anyone cares to have a look.
