99 5.9 durango hard start
Old 07-18-2004, 05:49 PM
davidb's Avatar
davidb
davidb is offline
Default 99 5.9 durango hard start
ive got a 99 durango 5.9l with 92k on it just recently it started to act up.
it starts hard i mean that it cranks for a long time before starting,aprox 10 to 15 sec. before starting ive done a tune up on it but didnt correct the problem,wondering if its the fuel filter? or someting else? any input would help
Old 07-18-2004, 06:11 PM
Dodgegirl19's Avatar
Dodgegirl19
Dodgegirl19 is offline
Lady Administrator
Default RE: 99 5.9 durango hard start
Could be fuel pump... perhaps the battery is starting to die... but I'd start with the fuel pump. "Test" it by turning the key to the on position, but not cranking the engine... then off, then on, then off, then on, then off... then start it... this process primes the fuel pump... if it starts up right away... I would think it's the fuel pump starting to go.
~Amanda
Old 07-18-2004, 06:49 PM
davidb's Avatar
davidb
davidb is offline
it dosnt do it all the time though it will do it three out of four times then only once in a day or sometimes all the time in one day,becoming more frequent
Old 07-18-2004, 07:46 PM
JCswm's Avatar
JCswm
JCswm is offline
NO: 18-36-98
SUBJECT: Start And Stall, Idle Undershoot - Lost Idle Air Control (IAC) Steps
DATE: Dec. 18, 1998
NOTE: THIS INFORMATION APPLIES TO VEHICLES EQUIPPED WITH GASOLINE ENGINES BUILT PRIOR TO DEC. 18, 1998 (MDH 1218XX).
SYMPTOM/CONDITION:
Some vehicles may exhibit an idle undershoot or die out during engine starting and may be caused by IAC lost steps. This condition is more likely to occur during cold weather, low battery voltage, cold engine start, and quick ignition key "On" - "Off" operation.
Idle undershoot will cause a long crank time and Lost Idle air control steps will make it run rough after it does start
The fix is a PCM flash.... look under you hood for a sticker with an updated PCM part#. If you can't find one have the dealer Flash it. It might fix your problem
John
Old 08-19-2019, 06:20 PM
Dawn Tolliver's Avatar
Dawn Tolliver
Dawn Tolliver is offline
Originally Posted by jcswm
idle undershoot will cause a long crank time and lost idle air control steps will make it run rough after it does start
the fix is a pcm flash.... Look under you hood for a sticker with an updated pcm part#. If you can't find one have the dealer flash it. It might fix your problem
john
Quick Reply: 99 5.9 durango hard start
