Wheels & Tires Discuss rims and tires here.
Sponsored by:
Sponsored by:
Old 08-10-2015, 07:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Dodge wheels interchange with Ford?
Old 10-21-2006, 01:20 AM
racer9's Avatar
racer9
racer9 is offline
Default Dodge wheels interchange with Ford?
3/4 ton Ford aluminum wheels look sharp, will they fit my 3/4 ton '96 Dodge with 16" tires?
Would I need to find certain years?
What other oem wheels will fit?
Thanks.
Old 10-26-2006, 08:19 PM
Ben@tirerack's Avatar
Ben@tirerack
Ben@tirerack is offline
Default RE: Dodge wheels interchange with Ford?
If you have a 1500 it won't take an F250 wheel because those are usually 8 lugs. If you have a 2500 and it's an older F250, the bolt patterns may match up, although whether the offset is right is another question. Generally I wouldn't expect them to work.
Quick Reply: Dodge wheels interchange with Ford?
