oil pan removal
Old 10-18-2006, 10:26 PM
press1280's Avatar
press1280
press1280 is offline
Default oil pan removal
I'm needing to replace the oil pan gasket and in Haynes it says the motor mount needs to be removed. However,it says in another chapter that you need to support the motor with a block of wood under the oil pan. How do you guys take off the oil pan? Is there a way to get it off without removing motor mounts?
Old 10-18-2006, 10:50 PM
ZiggyNeon's Avatar
ZiggyNeon
ZiggyNeon is offline
Default RE: oil pan removal
what year you have?
Edit : have to have a 96-99 huh
Old 10-18-2006, 10:58 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
front motor mount bracket does need to be removed.....if your careful and your other mounts are good, then you dont have to support the engine....but the motor will swing back a little when you take off the mount....or support it under the trans
Old 10-19-2006, 12:36 AM
das2123's Avatar
das2123
das2123 is offline
Just support it with a jackstand or another jack.
Old 10-19-2006, 10:27 AM
press1280's Avatar
press1280
Sorry, it's a 95 SOHC. So there's another spot on the engine that I can support it from other than the oil pan?
Old 10-19-2006, 01:08 PM
das2123's Avatar
das2123
das2123 is offline
The tranny.
Old 10-19-2006, 03:28 PM
ZiggyNeon's Avatar
ZiggyNeon
are you sure your looking at the manual right i thought on a 95 you didnt have to take the mount off just the oil pan bolts...i could be wrong though
Old 10-19-2006, 04:26 PM
spudsterier
in order to get all the oil pan bolts off you wave to remove the mount bracket.....since there is one or two bolts back there
Old 10-20-2006, 04:52 AM
racerx55's Avatar
racerx55
racerx55 is offline
use the E brake or block the wheels to hold it still, take off the front mount and all the pan bolts, you dont have to support it with anything, the 2 side mounts hold it up just fine, they hold it in the car now, all the front one does is keep it from flipping over when you accelerate,
Old 10-20-2006, 10:25 AM
press1280's Avatar
press1280
So support from the tranny pan then?
Quick Reply: oil pan removal
