Installing a stereo
Old 07-14-2004, 03:35 AM
mephisto's Avatar
mephisto
mephisto is offline
Default Installing a stereo
I have 2004 neon. I just bought a stock stereo and I need help installing it. Any help would be great.
Old 07-14-2004, 04:00 AM
KlerricK's Avatar
KlerricK
KlerricK is offline
Default RE: Installing a stereo
Help with what exactly? taking the dash apart? wiring it? and what do you mean you bought a stock stereo? do you mean aftermarket? I can help, but i need more info!
Old 07-14-2004, 04:15 AM
mephisto's Avatar
mephisto
mephisto is offline
taking the dash apart?yes
wiring it?yes
and what do you mean you bought a stock stereo?a stock stereo that i bought on ebay, form a2004 neon cd palyer.
do you mean aftermarket?no
I can help, but i need more info! thanks
Old 07-14-2004, 04:20 AM
KlerricK's Avatar
KlerricK
KlerricK is offline
Dash comes apart like so: You must pop out the two air vents up top, a small flat-headed screwdriver can help you there. Then pop out the trim piece that surrounds the radio/ac cluster. There are four hex bolts holding in the radio. Undo all four and out comes the radio. If you are just swapping a cassette/AM/FM radio to the CD/AM/FM radio, the plugs should be the same just plug in and put dash back together. If it were up to me, I would invest in an aftermarket radio which would give you stronger, cleaner power and room to add amps/subs/etc in the future. If you know that you will not be doing that, then maybe the stock radio is good enough for you. Hope this helps, if it doesn't let me know.
- Chris
Old 07-14-2004, 12:49 PM
techmanbd's Avatar
techmanbd
techmanbd is offline
ORIGINAL: KlerricK
- Chris
Forgot one thing at least in the 2004's, after you pop out the vents there are 2 screws behind them that holds the trim piece to the dash,
Old 07-31-2004, 12:31 AM
mephisto's Avatar
mephisto
mephisto is offline
Thanks.
Old 08-04-2004, 11:21 PM
sushi423's Avatar
sushi423
sushi423 is offline
Can i use these directions for my 1998 Neon... If the dash is different then please let me know how to take that off. Im getting my car tommarow and when i get paid im going to put in my alpine mp3 player.
Thank You
Old 08-05-2004, 03:33 AM
KlerricK's Avatar
KlerricK
KlerricK is offline
They ARE not the same. With a 1st gen Neon, you have to pull down the ash tray and depress the black piece in the center of it. The ash tray will then slide out. With that out of the way, you must start prying away at the plastic trim piece that surrounds the radio. Once this is out, undo the screws and, tada, out comes the radio. You will need a mounting kit and a wiring kit to make your life easy. These are readily available at a local car stereo store....
Old 08-05-2004, 04:39 AM
sushi423's Avatar
sushi423
sushi423 is offline
I have plenty of experience with installing cds players other than that every cars dash is deiffernt so i CAN't do every install wihtout help.
So yea, thanks for helping me wiht the neons dash im sure ill figure it out.
Old 07-01-2011, 01:01 AM
mgill1141's Avatar
mgill1141
mgill1141 is offline
Default 2001 neon stereo removal
I just bought a 2001 neon and I want to change the radio system but I'm not sure how to remove my old system, or is it the same as a newer neon were a pop the vents out on the dash?
Quick Reply: Installing a stereo
