General Tech Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
P0456 Code fix ideas?
Old 09-27-2006, 01:21 AM
imnothot02's Avatar
imnothot02
imnothot02 is offline
Default P0456 Code fix ideas?
Tryed the gas cap[:-]...reset the computer[:-], check engine light comes on after about a week, I dont see any loose hoses or anything, checked all of them nothing looks worn or cracked, this is all on a 2002 dodge dakota slt 4.7l v-8
Old 09-27-2006, 02:18 AM
The Burning Rom's Avatar
The Burning Rom
The Burning Rom is offline
Default RE: P0456 Code fix ideas?
Did you replace the gas cap with a Mopar gas cap? It's very common with the Dakotas.
From what I understand, this is also a code that's common.
There's more info on it here: http://www.obd-codes.com/forums/454-...ge-dakota.html
Old 10-07-2006, 04:07 PM
timwag2001's Avatar
timwag2001
timwag2001 is offline
check where the gas cap screws on. look for any corrosion. also where the stem from the tank meets the underside of your bed. do you smell any gas odors at any time?
Old 09-06-2007, 07:34 PM
middletone's Avatar
middletone
middletone is offline
my 02 stratus has the code 0456..will that cause a leak in the ac system. i just filled the ac with 2 tanks of freon today..3 hrs later..blowing hot air again..
help.
tony
Old 09-06-2007, 09:15 PM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
Open the hood, on the left side of the engine, look for a series of vacuum lines. You will see a cap on a valve with several vacuum lines coming to it. Inspect all of the hoses and replace any cracked ones. Also look at the hoses under the bed that go to the vapor canister. Replace any hoses that are cracked or split.... Very common problem.....
Old 09-06-2007, 10:53 PM
dishdude2k's Avatar
dishdude2k
dishdude2k is offline
no.. the evap code has NOTHING to do with your a/c leaking freon... if you have a blacklight .. go to the parts store and get some dye to put in.. then run it dry again.. use that black light to find the leak.. more than likely the high side line.. or a fitting needs to be tightened
Quick Reply: P0456 Code fix ideas?
