Fuse box layout for 94 Dakota
Old 09-08-2006, 10:44 PM
Broken Truck's Avatar
Broken Truck
Broken Truck is offline
Default Fuse box layout for 94 Dakota
Hello Dakota family, I have a Dakota sport 94 and have been trying to find out what all those numbers mean on my fuse box.
It does not say headlights, AC etc it only has numbers so if someone could please send me a layout I will be very thankful or at least tell me where I can find this info. I have a Haynes repair manual but nothing about the fuse box layout.
Old 09-08-2006, 11:56 PM
dodgerules86's Avatar
dodgerules86
dodgerules86 is offline
Default RE: Fuse box layout for 94 Dakota
Here's the info I believe you are looking for.
If you got any more questions, feel free to post back.
Old 09-09-2006, 03:29 AM
Broken Truck
Looks like this maybe do the trick, many thanks to you. I do have one other questions that maybe you can help me with, My heater\AC blower motor one quit working on low then med & now high I have been told that this is a fried resistor block that is either located under the dash or under the hood in some models. Any idea where it might be on a Dakota 94 model?
[IMG]local://upfiles/43247/4F26B22BBFA64F5D9ADB764E7FB27F5A.jpg[/IMG]
Old 09-09-2006, 03:39 AM
dodgerules86
The blower motor resistor block. Ah, yes.
As pointed out in the 1st Gen FAQs (at the top of the Gen 1 main page), this is located on the passenger side of the firewall.
As shown in the picture:
[IMG]local://upfiles/948/A6C7D0F009614875885D4659A1DFA4FB.jpg[/IMG]
Disconnect the electrical connector, and remove the screws. Remove bad block. Installation is reverse of removal. Pretty simple, which makes everyone happy .
Old 09-09-2006, 03:49 AM
Broken Truck
Can this be purchased at a local automotive store or is this a dealer part only?
I am still learning what’s what you can and can't buy at the auto store
If I get to buggy sorry about that.
Old 09-09-2006, 03:55 AM
dodgerules86
Hmm.. after a brief search, I could not find a blower resistor on NAPA or AutoZone's websites. However, that does not mean they do not carry them.
However, I have heard these resistors are only about $10 at the dealer, so, your not going to have to hand over an arm and leg to purchase.
Old 09-09-2006, 06:53 AM
Chump's Avatar
Chump
Chump is offline
4462841 RESISTOR, A/C
This is the dealer part number. NAPA may be starting to stock this part also. They burn up quite often because they are exposed to water and junk from under the truck. Check the connector and its wiring terminals for signs of excess heat, replace the connector if there are any problems or you will get even shorter life from the resistor.
The above part number crosses over to NAPA# ECHBR85
Old 09-12-2006, 02:11 AM
Broken Truck
Thanks for the info and the reply.
Old 09-12-2006, 02:15 AM
Broken Truck
Is there a way we can delete a post, this is my second post on this subject and wanting to delete the first post. Any ideas on this?
Quick Reply: Fuse box layout for 94 Dakota
