Neon Sensor and Part Locations
Old 09-07-2006, 01:43 PM
das2123's Avatar
das2123
das2123 is offline
Old 10-09-2008, 12:30 AM
ajpranger's Avatar
ajpranger
ajpranger is offline
Question Burnt Hose?
sorry
Old 04-15-2009, 07:32 PM
rvrfsh's Avatar
rvrfsh
rvrfsh is offline
Default location not accurate for crank sensor
I have a 2005 neon and tryed to follow directions from my chiltons repair manual and from directions given in this forum but my crank sensor was not behind the drive axle on passenger side but on the radiator side of block rite below the starter. I hope this helps because it took awhile for me to find.
Old 06-01-2009, 10:41 PM
9R/T.4door8's Avatar
9R/T.4door8
9R/T.4door8 is offline
Default oil pressure sensor? 98 dohc
2 part ? 1) where is it, and 2) how wud i hook up an autometer oil pressure gauge?
Old 08-17-2009, 12:10 PM
mancinibig's Avatar
mancinibig
mancinibig is offline
Default 2005 Dodge neon sxt will not start.
2005 Dodge neon sxt will not start. Lights and everything work good, but when the key is turned the engine will not turn over. There is no click or any noise from the engine compartment ......please help
Old 08-18-2009, 08:00 AM
rvrfsh's Avatar
rvrfsh
rvrfsh is offline
Question any codes??
are you getting any codes and what are they??
Old 01-10-2010, 10:17 PM
myneonbeater's Avatar
myneonbeater
myneonbeater is offline
95 neon highline, speedometer dances sometimes stops completely, going to zero, the rev meter doesnt work either when this happens . i also need a diagrahm of hoe to fix the airbag spring, it has caused the airbag light to come on and the horn to stop working
Old 08-15-2010, 01:17 PM
DOUG'SREDNEON's Avatar
DOUG'SREDNEON
DOUG'SREDNEON is offline
Exclamation I'm sure this has come up before,
error code p0172? BANK 1 RICH.
Any one have a common idea or know of a common failing in neon's that brings this error code and makes the car run super rough? any help would be apreciated.
Old 08-15-2010, 01:22 PM
DOUG'SREDNEON
the circuit boards were soldered poorly. you need to remove and take apart the spedo housing. re-solder the biggest solder points on the circuit board on the back of the spedo.
Old 12-15-2010, 11:13 PM
Big Lars's Avatar
Big Lars
Big Lars is offline
Default New To Site
No spark, 97 Neon. No voltage at coilpack orange wire with key on, what is next?
Quick Reply: Neon Sensor and Part Locations
