Dash/interior lights flicker and gauges jump
Old 09-01-2006, 03:15 AM
smokinsarge's Avatar
smokinsarge
smokinsarge is offline
Default Dash/interior lights flicker and gauges jump
I have a 2002 Dodge Neon SXT with about 72050. One day I started it up and the gauges started jumping up and down like you were turning it off and on. All lights on the instrument panel and the interior if they are on will flicker from bright to dim and so on along with the gauges. It doesnt seem to bother any other electrical components. Power windows work fine along with everything else except for the gauges and interior lights. I can be listening to the radio and the clock and lights just go off and on and bright to dim, but the radio stays on. Sometimes it does it as soon as I start it up and sometime after I have been driving. Sometimes it will go back to normal for a little bit then start going crazy again. After its been doing this for awhile the gauges will just move slightly. The odometer will be showing like 72010 and then 72009 or whatever the milage is at that time when it going off and on.
Any ideas would be greatly appreciated.
Old 09-01-2006, 03:17 AM
spikeymikey87's Avatar
spikeymikey87
spikeymikey87 is offline
Default RE: Dash/interior lights flicker and gauges jump
check your alternator
Old 09-01-2006, 04:52 AM
smokinsarge
Thanks Ill check that out.
Cant I do that myself by taking off one of the cables on the battery. Cant remeber which one.
Old 09-01-2006, 10:50 AM
kookie_guy's Avatar
kookie_guy
kookie_guy is offline
to check your alternator, start your car, then while it's running, pull off the positive terminal from your battery. If your alternator is good, you should NOT notice a change in the idle speed of your car. If your idle speed suddenly drops or you car dies all together, your alternator is shot.
Old 09-02-2006, 02:33 AM
ewetho's Avatar
ewetho
ewetho is offline
You might want to check panel dimming control on left side of steering wheel on dash. It may be bad.
Or possibly a bad cluster or ground.
Old 09-02-2006, 08:11 AM
smokinsarge
Thanks for the feedback.
Quick Reply: Dash/interior lights flicker and gauges jump
