How to disable key in ignition alert.
Old 08-29-2006, 06:51 PM
DUMBDAK's Avatar
DUMBDAK
DUMBDAK is offline
Default How to disable key in ignition alert.
OK guys, I bought my 05 Dakota for working around the farm. And when I work I like to have the radio on. And when I have the radio on I like to have the doors open so I can hear the thing. But I don't whant to hear that Stupid Nanny key in the ingition alarm. How can I disable this thing. The alarm seems to be way up underneath the dash board and has one of those sounds that you cant tell where it's comming from.
Old 08-29-2006, 08:50 PM
Frenchy's Avatar
Frenchy
Frenchy is offline
Default RE: How to disable key in ignition alert.
Turn the key forward for one. To the on position, but don't start it.
Old 08-29-2006, 09:00 PM
tasmanohio's Avatar
tasmanohio
tasmanohio is offline
cut the key sence wire
Old 08-29-2006, 09:50 PM
dodgerules86's Avatar
dodgerules86
dodgerules86 is offline
Either do what Frenchy said (which is known as the "accessory" setting), or you can
ORIGINAL: tasmanohio
Here's a pin-out.
Your looking for the violet and tan wire.
[IMG]local://upfiles/948/6C04936C7CA043D580829C7A49DB2C61.gif[/IMG]
Old 08-29-2006, 11:18 PM
SinceOne's Avatar
SinceOne
SinceOne is offline
actually.. to switch to 'acc' u have to turn the key the oppossite direction.. towards you instead of forward.
but like frenchy said.. is it bad to do that? because their are a couple lights that go on.. i think one of them in the alternator light not sure.
Old 08-30-2006, 12:44 AM
dodgerules86
As long as the engine is not running, the alternator light and low oil-pressure light should cause no alarm. Now, if lights such as the airbag or ABS/brake lights do not go on after the bulb/system test, there is a problem in that particular system.
Old 08-30-2006, 03:32 AM
superdak05's Avatar
superdak05
superdak05 is offline
do like what i did. remove rear panel and attach a set of speaker wires to the ones in the truck and get a cheap of speakers and rest them on the cab of the truck
Old 09-25-2006, 06:27 PM
DUMBDAK's Avatar
DUMBDAK
DUMBDAK is offline
Thanks All,
The Nanny tone works in the accessory position too, however you can have the passenger door open with the radio on with out nanny but both doors set it off.
dodgerules86; Can you tell me about where that connectory is?
Old 09-25-2006, 09:45 PM
dodgerules86
ORIGINAL: DUMBDAK
Appears to be on the left side of steering column (see picture)
[IMG]local://upfiles/948/D84E799A60824AFDB8F3A1F024E0311E.gif[/IMG]
Old 09-26-2006, 01:25 PM
DUMBDAK's Avatar
DUMBDAK
DUMBDAK is offline
Thanks dodgerules86! You must have connections on the inside!
Quick Reply: How to disable key in ignition alert.
