factory amp location and wiring
Anyone know where the factory amp is mounted in these babies and the wiring code? I installed 2 amps but I used step downs off the rear speaker leads. It worked fine for a while but now it is cutting the rear deck speakers out every now and then (one amp wired to it). I talked to a stereo shop and they said that is because I am amplifing an amplified signal. He knows of another case that the customers did the same thing. (not a dodge)..I have to get my signal pre the factory amp. It doesnt cut out all the time. Enough to be annoying...The shop couldnt help me because they havent wired up a 06 charger yet.
