Notices
Detailing Discuss detailing your ride inside and out here.
Removing road line paint
Old 08-12-2006, 01:34 PM
Queenbee's Avatar
Queenbee
Queenbee is offline
Default Removing road line paint
Hey all!! I just bought a '03 QC 2 weeks ago and the previous owners ran over fresh line paint. Is there a good product or way to remove this crap? It's on the flares, under the bottom of the truck paint (front to rear) and up under the wheel cover. Looks like hell. I was thinking of using a soft brush or rubber scraper? Thanks bunch![sm=smiley16.gif]
Old 08-13-2006, 04:51 PM
djr04's Avatar
djr04
djr04 is offline
Default RE: Removing road line paint
First thing to try should be a clay bar with spray wax as the lubricant on all your painted surfaces. If you keep at it and keep the bar lubricated, It will remove all of that paint spray without damaging your vehicles paint.
Old 08-14-2006, 09:37 PM
Queenbee's Avatar
Queenbee
Queenbee is offline
I've read about the clay bar and watched a video on Adam's Car Products website. I'd like to get their's but don't want to wait for it to get here as I can't find it here in Georgia. Is Mother's or Meguires equivilent? I know both have been around for years. Thanks.
Old 08-14-2006, 10:35 PM
griz1200's Avatar
griz1200
griz1200 is offline
Any brand of clay bar will work just fine. You can pick it up at either AutoZone or Advance and usually comes with a spray bottle of lubricant. Spray wax is a good lube too and regular old Windex glass cleaner works just as well. Word of caution...if you happen to drop the clay bar while using it, make sure it's free of any dirt or sand etc. as it will damage the surface. I put a piece of clean plastic under the area just in case.
Old 09-05-2006, 06:18 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Zeppelinrocks is offline
i have had bad experiences with the clay, it didnt remove any of the paint off my truck
Old 09-13-2006, 07:49 PM
bdering's Avatar
bdering
bdering is offline
Hi Zeppelinrocks,
Clay may not remove all contamination. However, it is usually the best place to start before working with progressively harsher solutions such as rubbing compound or wet sanding. If you still had paint (I am assuming foreign paint overspray or splatters), then perhaps the contamination was able to bond lightly with your original paint. If that is the case, then you would need to proceed to more aggressive solutions.
Old 02-23-2007, 11:54 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
I know this post is old but use Lacquer thinner on a red shop rag rewax area afterwards for the inside of the fenders where its not painted use flat black paint . . . do this step first
Quick Reply: Removing road line paint
