OBDII P2509 code
Old 08-04-2006, 11:39 PM
oldVOR's Avatar
oldVOR
oldVOR is offline
Default OBDII P2509 code
Can't seem to find a reference for this code.
It's the only one that comes up on the diagnostic display.
Any help appreciated!
Thanks......
Old 08-05-2006, 11:40 AM
max39's Avatar
max39
max39 is offline
Default RE: OBDII P2509 code
are you using a scanner? the keyon/keyoff * 3 method didn't work for me. I got a 1693 but the scanner showed that plus another code.
Anyway, I googled and found this:
http://www.3800pro.com/lists/obd2codes.html
Old 08-05-2006, 12:31 PM
oldVOR's Avatar
oldVOR
oldVOR is offline
I used the key on/off method and initially found it to be a bit tricky to get it right. The trick is not to actually turn it back too far to the "LOCK" position but just between the "ON/RUN" and "OFF" position. I can do it consistently with this method......initially turn to "ON/RUN" and back to "OFF", the "OFF" is my first count and I do it twice more ending with a half count being the "ON/RUN" position.
ON/RUN - OFF (one)
ON/RUN - OFF (two)
ON/RUN - OFF (three)
ON/RUN (display will show codes if any or "DONE" if none)
Thanks for the link to the OBDII codes, it is the most comprehensive list I've seen thus far......
Now, I wonder how or why I'm getting the P2509 fault "ECM/PCM Power Input Signal Intermittent"......especially since I've not noticed any issues with the truck at all......
Thoughts from the collective group?????
Quick Reply: OBDII P2509 code
