Grease Fittings?
Old 07-23-2006, 11:35 PM
ARbowhunter7's Avatar
ARbowhunter7
ARbowhunter7 is offline
Default Grease Fittings?
Well I got out the old grease gun today to grease the front end on my 01 1500 Off Road, and there's only one regular grease fitting under there. All the other 6 or so boots don't have the regular grease fittings, they've got what looks like around a 1/2" nut with a threaded base. What's that... a weird fitting, or maybe a sealed boot? Whatever it is, it needs grease bad. The boots are empty, dry, and starting to crack. Thanks in advance for the help.
Old 07-23-2006, 11:51 PM
wildwolf59's Avatar
wildwolf59
wildwolf59 is offline
Default RE: Grease Fittings?
yup....they are nongreasable(somebodys brilliant idea) and they make some noise when they go out......lukes link has some fittings that you can buy when they go bad and start sqeaking and they are greasable!!!!!!! www.lukeslink.com
Old 07-23-2006, 11:57 PM
DODGEIT105's Avatar
DODGEIT105
DODGEIT105 is offline
This is typical of Dodge trucks. Not many serviceable parts underneath. I just a few months ago spent $1500.00 to replace all four ball joints, tierod ends, and tracbar. Plus and alignment after all that was done. If you eventually replace any of those parts and you will if you keep the truck long enough make sure the replacement parts have the zerk fittings on them so that they can be serviced.
Old 07-24-2006, 12:13 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Off_Road_Teacher is offline
I just installed zerk fittings on everything I could under there on my truck. For about $3 I was able to get enough fittings for everything. Worked well so far.
Old 07-24-2006, 03:40 AM
Racinfan83's Avatar
Racinfan83
Racinfan83 is offline
How did you install them? Did you have to drill and tap the bottoms of the rod ends, etc for the grease fittings or what?
Old 07-25-2006, 11:37 PM
Off_Road_Teacher
That is exactly what i did. Except i used the press in fittings instead of the threaded ones. There is not enough material to run threads, so i went with the press ins. They have worked very well so far.
Old 07-26-2006, 12:59 AM
bamory's Avatar
bamory
bamory is offline
So far short of the U-Joint, I have replaced with parts that have grease fittings. I chose the sealed u joint because I have had both and they last about the same amount of time
Old 07-26-2006, 02:26 AM
gamagoat6x6's Avatar
gamagoat6x6
gamagoat6x6 is offline
I just drill a hole and use self tapping zerks in everything including the lower pivots on the sway bar links.
[IMG]local://upfiles/36447/12E979C4DB2D47C295977F84585801BD.jpg[/IMG]
Old 07-26-2006, 10:14 PM
wildwolf59's Avatar
wildwolf59
ok guys....can u wxplain how you do these zerk fittings and where do you get them at?i have a squeak in one of them
Old 07-26-2006, 11:41 PM
gamagoat6x6
NAPA stocks them locally here.
Quick Reply: Grease Fittings?
