Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
How to disable Daytime running lights?
Old 05-20-2006, 05:28 PM
rtabcum's Avatar
rtabcum
rtabcum is offline
Default How to disable Daytime running lights?
Anyone know how to disable this feature?
Thanks
RT
Old 05-20-2006, 09:39 PM
fdxreg's Avatar
fdxreg
fdxreg is offline
Default RE: How to disable Daytime running lights?
Fuse panel under the driver seat has a number of fuses that need to be pulled. You can do this without disabling the headlamps from working at night. The bulbs aren't cheap to replace so I recommend it if you do a lot of daytime driving.
Old 06-29-2006, 04:43 AM
rtabcum's Avatar
rtabcum
rtabcum is offline
Thank you...
It worked. I removed 2 fuses and now the headlamp switch operates normally. The high/low beam worked fine too.
RT
Old 04-19-2007, 03:00 AM
Doo Hauler's Avatar
Doo Hauler
Doo Hauler is offline
Which fuses (number/position) did you remove? I need to enable my DRL on my 06 for work purposes and it did not come with DRL option. It's only a $50 option I cant imagine there being much to it.
Thanks
Joe
Old 09-26-2007, 02:09 PM
bsedor's Avatar
bsedor
bsedor is offline
Anyone know how to disable the DRL's on teh 2007 Sprinter?
Old 12-16-2009, 03:45 PM
Neon Guy 05's Avatar
Neon Guy 05
Neon Guy 05 is offline
Default How do I disable daytime running lights (DRL) on a 2005 Dodge Neon?
I looked in the fuse box where two DRL fuses would go...nothing in there yet the headlights still come on when I start it up. Help!
Old 05-24-2010, 07:42 AM
fastpark's Avatar
fastpark
fastpark is offline
Default DRL's on teh 2007 Sprinter
I've heard the only way to do it is with the Star scan tool that the dodge dealer uses. Let me know if you find out any different.
Old 05-26-2010, 05:42 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
the only way to disable on an '07 is with a scan tool, sorry.
Old 06-15-2010, 10:49 PM
katecon1's Avatar
katecon1
katecon1 is offline
New here, I have a 2002 dodge caravan sport and my running lights do not work, all other lights function properly, fuses are good as well as relay switches. I was told to replace my body control module, does this seem right
Old 06-18-2010, 05:11 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
Hi Kate, welcome to the forum. This is actually the sprinter section, there is a section for caravan's but we don't punish you until your second mishap
The daytime running lamps are turned on by changing the country code in the body controller from USA to Canada. Daytime running lamps are required in Canada so the BCM turns them on in that code. It is very possible that all you need to do is have the country code changed.
Quick Reply: How to disable Daytime running lights?
