No power runs rough misfire 03 neon sxt
Old 05-14-2006, 10:48 PM
porovich's Avatar
porovich
porovich is offline
Default No power runs rough misfire 03 neon sxt
My 03 neon sxt runs like crap It has absolutely no power runs rough misfires I changed the spark plugs and it ran good for 1 day I also changed the air filter It stalls shudders and sometimes dies Help
Old 05-14-2006, 10:50 PM
leadspud's Avatar
leadspud
leadspud is offline
Default RE: No power runs rough misfire 03 neon sxt
coil or plug wires? Do you have any codes
Old 05-14-2006, 10:59 PM
porovich's Avatar
porovich
porovich is offline
P0340 P0440 P0038
Old 05-14-2006, 11:57 PM
ewetho's Avatar
ewetho
ewetho is offline
Check them out in order. Solve the first code out first always. So you have a CAM sensor Circuit problem. Check make sure you cam sensor is plugged in and then probably time to replace it. Clear codes and go on.
Old 05-15-2006, 12:16 AM
porovich's Avatar
porovich
porovich is offline
where is the cam sensor on the car
Old 05-15-2006, 07:22 PM
2007CustomCaliber's Avatar
2007CustomCaliber
2007CustomCaliber is offline
my 2000 had misfire problems and it turned out to be the wires
Old 05-16-2006, 04:08 PM
tooslow's Avatar
tooslow
tooslow is offline
the cam sensor
on the driver side of the head it you have too move the wiring harnes and all those hoses too get too it
Old 05-16-2006, 06:57 PM
flamingpinhead's Avatar
flamingpinhead
flamingpinhead is offline
Section Moderator
first, try plugs & wires and coil.
edit:
when my srt had some rough running problems, it would run rough, lost power and would cut the rpms and sometimes overrev the motor without hitting the gas. it turns out the throttle positioning sensor was out of range, so the car's computer got 'confused'
Quick Reply: No power runs rough misfire 03 neon sxt
