"failsafe" thermostat...anyone have it?
searched and found nothing. went to autozone looking for a 180 t-stat, and they had the "failsafe" one that automatically opens at 260 degrees. so i bought it...anyone have it or no? also, does the alternator need to be removed? im thinkin so...will i get the same results that a normal 180 t-stat will give?
RE: "failsafe" thermostat...anyone have it?
You don't have to remove the alt., but it would make for easier access...see here, this adapter saves alot of time at work... https://dodgeforum.com/fb.asp?m=434089
My understanding of the failsafe t-stat, tho I've never used one, is that it can never stick closed...been the victim of a stuck closed t-stat before, 91 LeSabre, 90 degree weather, and cruising about 75...temp light come on! Alot of people say that t-stats don't/can't stick closed, but it's bs, 1sthand experience. I'd get it, it can't be any worse than a 'normal' t-stat.
http://www.pavementsucks.com/tech/tstat.php
They have a few pics. with info. You can work out the hose and tstat housing together. If the heater hose clamp is in the way, which it probably will be, you can push/turn it with a screwdriver without taking it off. Trim off the tab once it's out..... I went with a stant tstat. I prefer to use name brand products. Haven't heard of the one your talking about. Then again, at 260, I'll be shutting it down anyway.
i used to sell those when i wroked at oreillys and there junk. They will fail with in the first two weeks and you will be stuck with an open dt-stat. save your self the trouble and get a ultra stat from stant. better construction, better part, name brad.
thats the one iam running for two years now and no problems
along wiht hypertech.. they sell a crappy tstat... go to napa... best parts for the price!!!! myself and another member here had a hypertech fail on them.. although ours were stuck open... in the middle of winter .. almost as bad as sticking closed[:@]
I bought the same t-stat that you did and I haven't had any problems out of it yet and it has been in there for a good while now. Mine is also fail-safe. When I replaced the t-stat in mine I did have to pull the alt. off because it made everything easier to get to. But its up to you on that one.
