Transmission Cooler Install
Hi. I am seriously considering a B&M Transmission Cooler from Summit and was hoping for both help with the install and other's recommendations. Does anyone have a B&M cooler and do they like it. Does anyone recommend a different one. Could someone give me an easy step by step install with the tools I will need. This is the one I am considering:Transmission Cooler It looks like it comes with everything I will need. Does it? Thanks a lot!
RE: Transmission Cooler Install
I Have a Haden Heavy Duty cooler on my truck. My Ram has a factory Aux cooler. If you have a Factory Aux cooler then the hoses coming off of the Radiator will already be barbed and held on with hose clamps. I just removed on of the hoses and then ran the other cooler in line. Meaning from the radiator the hose runs to the stock aux cooler. Then to the new cooler then to the trans. Sorry i have no pictures but maybe this will help you.
I installed a Flex-a-lite part# 4232. I tried several of the smaller sizes (GVW ratings around 17,000-22,000), but they just didn't cut it at all (made almost no difference). Mine is rated at 32,000 GVW, and does a great job. I think the smaller ones would work fine if you bypass the radiator though.
That one you linked to looks pretty good. It is kinda small, but that's ok because it is thick. That combined with the fact that it is a plate and fin design should make it a decent cooler. Looks like everything you need is included.
Here is how I installed mine. There are other ways, but this has worked very well for me.
[IMG]local://upfiles/9095/8EEE0FB1E3A14AC0A0EC2F54720E40F7.jpg[/IMG]
Also, all auto Rams have a transmission cooler. They utulize the radiator for cooling. Stock trans line come off of the transmission, go into the radiator, and back out to the transmission. What you are looking for is if you have an auxillary trans cooler that was part of the towing package. It is sandwiched between the radiator and the condesor as mentioned. If you have that, you would probably be fine as is, or just replace it with a better cooler. If you have nothing (lines go into radiator and directly back to trans only), then installing a cooler would be a great idea to help prolong the life of your trans.
Hope this helps.
Hope this helps.
ORIGINAL: Sehr916
Okay thanks, Next chance I get I will check for the aux cooler.
Stupid question but. I always thought the radiator was to cool the engine coolant. How does a radiator also cool Transmission fluid as well? Thank you very much.
When I was researching buying a diesel (before I bought my V10) I read that a lot of guys that tow buy the coolers that you mount under the bed (with an electric fan on them). Those seemed to be the most effective, due to their size. They probably wouldn't be a good idea if you're someone that does a lot of wheeling though.
Also, check out this post for an alternative way to install a trans cooler.
https://dodgeforum.com/m_430898/tm.htm
Look for the post by Racinfan83. He has a good trans cooler setup and a nice write up of his install.
