Left rear door won't open
Old 04-12-2006, 04:29 AM
guardrail's Avatar
guardrail
guardrail is offline
Default Left rear door won't open
The handle will move, but it won't unlatch from the body.
HELP!
Old 04-12-2006, 05:11 AM
tib2001's Avatar
tib2001
tib2001 is offline
Default RE: Left rear door won't open
perhaps the cable broke....
Old 04-12-2006, 05:12 AM
Eric326's Avatar
Eric326
Eric326 is offline
Are you sure that the door is unlocking? Just checking because I have had multiple locking mechanisms on vehicles go over the years where unlocking from the outside stopped working. Can you open the door from the inside ok?
Eric Terry
Semper Fidelis
Old 04-12-2006, 05:21 AM
guardrail's Avatar
guardrail
ORIGINAL: Eric326
Eric Terry
Semper Fidelis
No, the door won't open at all. It doesn't have a lock on it, only the front door locks.
Old 04-12-2006, 06:04 AM
Eric326's Avatar
Eric326
Eric326 is offline
Oh ok, its just a kick out door? Not a full door. Well Defintely going to have to take off the door panel for it and look underneathe the weather plastic. Sounds like that might be a little hard if you cant get the door open at all. If you can see the door latch you might be able to pop it open with a screw driver, I'm not sure what you can see with the door closed. Hopefully you can get the door panel off.
Eric Terry
Semper Fidelis
Old 04-12-2006, 09:58 AM
Fiero Guy's Avatar
Fiero Guy
Fiero Guy is offline
apparently the lower latches are known for freezing up....with the door closed.
I just had to replace mine, but luckily mine wouldn't latch on the bottom, instead of wouldn't un-latch.
It was like $70 new from the stealership, but at least I can latch the door now.
Old 04-12-2006, 11:22 AM
tib2001's Avatar
tib2001
tib2001 is offline
if it helps at all, the lower brackets on mine are rusted to crap, but I wire brushed them when I got the truck, and spray them with lube. the brackets on the door frame.
try spraying some PB Blaster in there.
but seriously, also check to see if the control cable snapped, or came off one of its connection points.
those door panels are easy to pull off.
just pull the screw in the non moving handle area. remove the screw that holds the moving handle in.
and yank on it around the window.
just be carefull not to break it near the front of the door where it is just a narrow strip.
(check for extra screws first)
Old 04-12-2006, 11:27 AM
hippie49445's Avatar
hippie49445
hippie49445 is offline
My right door is stuck. Every few months I have to crawl in the back and kick the door open. Once open I re-adjust the hinges. Pain in the a**.
Old 04-13-2006, 06:32 AM
guardrail's Avatar
guardrail
ORIGINAL: tib2001
Can I pull the panel off with the door closed, I can't find a way to get it open.
Old 04-13-2006, 07:51 PM
tib2001's Avatar
tib2001
tib2001 is offline
i would think you can pull it off at the front edge. mine has no clips right at the top, or bottom, they are a couple inches in....
Quick Reply: Left rear door won't open
