What size speakers does the neon have?
Old 03-30-2006, 02:18 AM
venum_us_2002's Avatar
venum_us_2002
venum_us_2002 is offline
Default What size speakers does the neon have?
I have a 2005 Dodge neon SXT and was wondering what size the speakers were in it?
Old 03-30-2006, 02:55 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
Default RE: What size speakers does the neon have?
they should be the same as a 200 neon....go to 2nd generation and i think it is almost at the bottom of the page...i dont think they changed
Old 03-30-2006, 12:27 PM
RadarLove's Avatar
RadarLove
RadarLove is offline
The rear speakers are 6x9", fronts are 6.5" and any aftermarket speaker should fit fine. Do the 2nd gens have the tweeters in the dash like the 1st gens (3.5"?)? For 1st gens, the fronts are actually "6.5s", which has to do with the mounting bracket I think. The Pioneers I installed in mine didn't line up with the holes correctly and I had to modify to fit. Most aftermarket speakers take this into account though, and have holes predrilled for various setups. People have also used 5.25" and 6.75" for the door speakers (on 1st gens).
Best of luck!
Old 03-30-2006, 03:03 PM
spudsterier
the doors on a first gen. actually are 6.75's....thats why 6.5's usually wont fit....
Old 03-31-2006, 03:40 AM
71RoadRunner's Avatar
71RoadRunner
71RoadRunner is offline
Dash: 3.5"
Doors: 6.5"
Rear: 6"X 9"
Old 03-31-2006, 06:10 AM
spudsterier
thats odd...i bought some 6.5's for my doos before and they were too small so i went and exchanged them for 6.75's and they fit perfect...but i guess that my car just has them like that and the rest and 6.5's
Old 05-26-2006, 04:27 AM
djmagic's Avatar
djmagic
djmagic is offline
For the back you could get a template, that's what I did.
Old 08-04-2006, 10:22 AM
fraggle_a's Avatar
fraggle_a
fraggle_a is offline
How do I get into the door to check the speakers?.
Does the speaker grill pop off like my old Saturn, or do I have to remove the whole door pannel like the wifes cursed cavalier?
... and how does one remove the pannel?
(02' second gen?)
Old 08-04-2006, 11:28 AM
QBall02's Avatar
QBall02
QBall02 is offline
ORIGINAL: fraggle_a
(02' second gen?)
Gotta remove the whole panel.
1) Remove the 3 philips head screws.
2) Pry along the sides and bottom to pop all of the fasteners off
3) Disconnect wires for power windows/mirrors (if equipped)
4) Remove the metal pieces that run from the door handle to the door latch
Then your door panel will come right off.
I just did this the other day and it was a piece of cake.
Old 08-04-2006, 03:15 PM
fraggle_a's Avatar
fraggle_a
Thanks man.
Howd you get the window handles off?.
The only electric equipment on my Neon is the sterio. Which Im cool with, less to go wrong.
Since Im just getting to the speaker at the bottom, I wonder if I can just pop the bottom part of the doortrim and get at it from underneath......
I just want to find out "why" the speaker is making a horrible noise through the base frequencies. Sounds like something is stuck in there on the cone.
Quick Reply: What size speakers does the neon have?
