TRANSMISSION OIL
Old 03-20-2006, 10:00 PM
cumminpower's Avatar
cumminpower
cumminpower is offline
Default TRANSMISSION OIL
I HAVE BEEN LOOKING AT MY MAINTENANCE BOOK, AND IT SAY I NEED TO CHANGE OUT MY TRANSMISSION OIL. WHAT KIND OF OIL SHOULD I USE IN MY MANUAL?
2003 2500 CTD
Old 03-21-2006, 10:26 AM
Drew's Avatar
Drew
Drew is offline
Default RE: TRANSMISSION OIL
that depends on which tranny you have, for the NV4500(5spd)
75W-90 Castrol Syntorque Synthetic
Mopar Manual Transmission Lubricant (PN 4637579)
GM Transmission oil (PN 12346191)
for the NV5600 (6spd)
Texaco Code 1874 MTX
Mopar 4761526
Dodge spec MS-9224 oil
Amsoil Series 3000 5W-30 engine oil
Old 03-21-2006, 03:25 PM
steved's Avatar
steved
steved is offline
ORIGINAL: Drew
Mopar 4761526
Actually for the 5600, Amsoil has a "MTL" specifically for the manuals now...no need for 5w30 oil...if his owner's manual is like mine, there is no scheduled drain for the 5600. I'm going to run Royal Purple SynchroMax in mine...Pennzoil is probably the easiest to come by in the local parts house...Pennzoil Synchromesh.
And the auto uses chrysler specific ATF+4 now...which I believe Amsoil ATF also meets the specs for ATF+4 as well.
steved
Old 04-03-2006, 04:18 PM
GRAHAM's Avatar
GRAHAM
GRAHAM is offline
ALL THE BEST ON YOUR TRANNY OIL CHANGE. I RUN AMS/OIL IN BOTH MY TRANNY AND DIFF, IT RUNS COOLER THAN THE ORGINAL !!!
GRAHAM
Old 04-21-2006, 01:46 PM
mc4you2's Avatar
mc4you2
mc4you2 is offline
Has anyone had any trouble with using this? "Amsoil Synthetic Manual Transmission and
Transaxle Gear Lube 75W-90 API GL-4" in their NV4500? I was looking at my trans, and it has a warning sticker on the side saying that if you use anything other than the 3 listed choices (Castrol, GM or Mopar) that "sever damage can result" [sm=confused06.gif] Is this just BS or has anyone used the Amsoil Trans Lube in theirs? Thanks for the input.
Mike
Old 04-21-2006, 06:53 PM
Drew's Avatar
Drew
Drew is offline
Mike. . .the answer is yes. I've seen pictures of a 5600 where the wrong oil was used and the bearing races were shot, bearings themselves were pitted, and the syncros were shattered.
then on top of that, New Venture Gear is no longer in buisness, New Process bought them and the patents they held when DC moved from NV to the G-56. long story short, parts for the NV35, 45, 56, and other trannies are in shorter and shorter supply. the only way to keep the tranny happy is to use the correct oil that is specified.
now in the next 2K or so miles I'm gunna need to change all the fluids. I have a source for all the AMSoil oils I need for a good price so I'll be able to tell how much different the AMSoil is over what I'm useing now.
I already have AMSoil in the engine of my taco and I can tell a little difference in the way the engine runs. I like it and will probably continue useing it.
Old 04-22-2006, 05:01 AM
mc4you2's Avatar
mc4you2
mc4you2 is offline
Thanks Drew, glad I asked! I am planning some mods, and I was considering doing a bumper to bumper switch to synthetics, so I did a search on the Amsoil website and according to their build list for my 98.5, it says to use the Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 in the NV4500. So I am just trying to be sure I am understanding you rightly. You are recommending going with what the NV sticker says only then? I noticed in your post earlier you had listed Amsoil use in the NV5600, but not the NV4500? Is that because of a difference between these 2 trannys? I have seen differing reports (mostly good) on Amsoil use around the web, and I am leaning towards the Amsoil still, but I surely value your opinion. Was the trans damage you mention from the Amsoil recommended Amsoil or just the wrong oil altogether?
Thanks,
Mike
Old 04-23-2006, 06:10 AM
Aaronon38s's Avatar
Aaronon38s
Aaronon38s is offline
My tranny took a dump on me when I bought it and the previous owner changed it with gear lube. Bearings siezed, cracked shafts, all that good stuff. After a shop rebuilt it and put GEAR LUBE BACK IN IT, it was shot again 1000 miles later. Granted it was Amsoil gear they put in it, but definetly the wrong type of oil. However, I run Amsoil in the engine and the correct Amsoil in the tranny with no problems anymore. If needed, give a call to the Amsoil reps and they will set you on the right track.
Old 04-23-2006, 01:58 PM
Drew's Avatar
Drew
Drew is offline
you are right Mike, the NV4500 and NV5600 use different fluids, however the NV3500 and NV5600 use the same fluids. go figure.
anyway, if you do use AMSoil, get the grade that NV suggests you use Aaron is a perfect example of what can happen if the wrong fluid is used.
these New Venture trannies are tough, but put the wrong fluid in them and they will blow apart
Old 04-23-2006, 02:40 PM
mc4you2's Avatar
mc4you2
mc4you2 is offline
Thanks guys, good info, much appreciated. I am anxious to see what the correct amsoil will do for me. I will be changing over soon.
Thanks,
Mike
Quick Reply: TRANSMISSION OIL
