rear lowering shackles
Old 03-04-2006, 11:43 PM
sonny t's Avatar
sonny t
sonny t is offline
Default rear lowering shackles
Has anyone installed any rear lowering shackles on thier 1500 RAM??? I called around today at some truck places to find some lowering shackles so I could lower the rear end 2 inches so it would level out the look of the truck. My responses were discouraging. Two places said that the shackles they had would only lower the truck 1 inch, not hardley worth the efort since you probably would not even be able to see a difference. Another shop said they had some that would lower it about an inch and a half. I was wondering if anyone has successfully lowered thier truck a full two inches with shackles and which ones they were????[:-]
Old 03-05-2006, 02:36 AM
krod's Avatar
krod
krod is offline
Default RE: rear lowering shackles
i got the djm shackles from ebay and they lowered the rear a inch and a half,overall looks good with the 20 inch wheels and tires.
Old 03-05-2006, 11:36 AM
steeringcolumn's Avatar
steeringcolumn
steeringcolumn is offline
Those are the same 1's I bought,only NOT off E-Bay,competition sales for $79!!!
I think they made a huge difference!!
Old 03-05-2006, 03:48 PM
rob[GL]'s Avatar
rob[GL]
rob[GL] is offline
What year?
If's it's a pre-2006 then just cranks your torsion bars 5-6 turns to get an extr 1.5-2" higher in the front, that'll level it out and look nice as hell. I did it on mine, and eventually I will tuck some 35's
Old 03-05-2006, 08:25 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
I got the ground force 2" drop shackles. They lowered the rear around 1.75 inches. Then I raised the torsion bars a little to really even things out.
Old 03-06-2006, 11:22 AM
steeringcolumn
ORIGINAL: rob[GL]
What year?
It has to be a 4X4 to have the adjustable "torsion bars"correct????
Old 03-06-2006, 12:20 PM
osteodoc08's Avatar
osteodoc08
osteodoc08 is offline
ORIGINAL: steeringcolumn
ORIGINAL: rob[GL]
What year?
Yes. 2wd has coil springs up front. On the 2wd trucks, you can also add the urethane spring spacers, but takes a little work since you have to take the front suspension apart.
Old 03-08-2006, 06:48 PM
aris9292's Avatar
aris9292
aris9292 is offline
Will that void the warranty by installing shackles??
Old 03-11-2006, 06:45 PM
GITRDONE75's Avatar
GITRDONE75
GITRDONE75 is offline
Contact Ground Force on the internet. I installed the shakles that poly. bushings. make sure to grease the outsides of the bushings before sliding them into the brckets or they will sqeak at every small bump. It's almost level but it does lower it alot more than you would think. Plus the shackles re acually shorter instead of longer. It's the way the leaf spring and shackles system is set up.
Old 03-12-2006, 03:28 PM
chefred112's Avatar
chefred112
chefred112 is offline
Contact Brian McClure at Slammed 1 Suspensions. He is the absolute guru for lowering Ram pickups...he supplied me my GroundForce shackles and already greased them for me too b4 shipping.... he does "slammed tours" do wher he drives to certain areas of the country to do drops an C notches and stuff..
http://slammed1suspensions.com/
Quick Reply: rear lowering shackles
