Old 08-05-2015, 12:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
2004 TSB's for Ram 1500
Old 03-04-2006, 01:47 AM
jastweed's Avatar
jastweed
jastweed is offline
Default 2004 TSB's for Ram 1500
Make : DODGE Model : RAM 1500 Year : 2004
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 2304605 Date of Bulletin: OCT 01, 2005
NHTSA Item Number: 10017637
Component: STRUCTURE:BODY
Summary:
WATER LEAK AT ROOF MOUNTED MARKER LAMPS. *SC
Check to Request Research. Submit below.
Service Bulletin Num : 2401305 Date of Bulletin: AUG 04, 2005
NHTSA Item Number: 10016603
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
AIR CONDITIONING (A/C) COOLING COIL ODOR. *TT
Service Bulletin Num : 05002 Date of Bulletin: APR 28, 2005
NHTSA Item Number: 10015075
Component: ENGINE AND ENGINE COOLING
Summary:
NEW WATER PUMP FOR 3.7L ENGINE - NO LONGER COMMON WITH 4.7L. ADVANCED SERVICE INFORMATION #05-002. *TT
Service Bulletin Num : 1801705 Date of Bulletin: APR 21, 2005
NHTSA Item Number: 10015060
Summary:
LONG CRANK TIMES IN AMBIENT TEMPERATURES BELOW FREEZING. *TT
Service Bulletin Num : 1801305 Date of Bulletin: APR 19, 2005
NHTSA Item Number: 10015058
Summary:
IDLE FLUCTUATION/DIAGNOSTIC TROUBLE CODES. *TT
Service Bulletin Num : 1801605 Date of Bulletin: APR 12, 2005
NHTSA Item Number: 10015068
Component: VEHICLE SPEED CONTROL
Summary:
THROTTLE BODY COKING. *TT
Service Bulletin Num : E09 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10015067
Component: EQUIPMENT:OTHER:LABELS
Summary:
EMISSIONS RECALL E09 - NEW VECI LABELS. *TT
Service Bulletin Num : 1804104 Date of Bulletin: OCT 25, 2004
NHTSA Item Number: 10010536
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
IMPROVED AUTOMATIC TRANSMISSION SHIFTING IN TOW/HAUL MODE. *EH
Service Bulletin Num : 42 Date of Bulletin: OCT 01, 2004
NHTSA Item Number: 10010563
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
EMISSIONS RECALL D42. REPROGRAM PCM - OBD CALIBRATION. THE POWERTRAIN CONTROL MODULE (PCM) WAS INADVERTENTLY PROGRAMMED WITH INCORRECT SOFTWARE. THIS CAN CAUSE THE ON-BOARD DIAGNOSTIC (OBD) SYSTEM TO MALFUNCTION. *TT
Service Bulletin Num : 1803704 Date of Bulletin: SEP 27, 2004
NHTSA Item Number: 10010488
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
FUEL ECONOMY IMPROVEMENT, WHITE SMOKE ON START UP, ACCURACY OF FUEL MILEAGE IN OVERHEAD CONSOLE DISPLAY. FLASH. *TT
Service Bulletin Num : 0311 Date of Bulletin: NOV 25, 2003
NHTSA Item Number: 10006305
Component: ELECTRICAL SYSTEM
Summary:
RECOMMENDED 12V SWITCHED ACCESSORY SOURCES. THIS IS A FISHER SERVICE BULLETIN. *MR
Service Bulletin Num : 03014 Date of Bulletin: AUG 29, 2003
NHTSA Item Number: 10003520
Summary:
SERVICE ACTION 03014 - POWERTRAIN CONTROL MODULE (PCM) ELECTRICAL CONNECTOR SEAL INSPECTION/REPAIR PROCEDURE. *TT
Old 03-04-2006, 01:55 AM
jastweed's Avatar
jastweed
jastweed is offline
Default RE: 2004 TSB's for Ram 1500
Missed one
Make : DODGE Model : 1500 Year : 2004
Service Bulletin Num : 0500105 Date of Bulletin: JAN 06, 2005
NHTSA Item Number: 10012317
Component: SERVICE BRAKES, HYDRAULIC
Summary:
BRAKE SHUDDER OR VIBRATION. *EH
Old 03-04-2006, 11:27 AM
mpd2436's Avatar
mpd2436
mpd2436 is offline
I'm a little confused, are these possible problems with the 04 1500's or are they recalls?
Old 03-04-2006, 12:47 PM
jastweed's Avatar
jastweed
jastweed is offline
They are techinical service bulletins for the 2004 Dodge Ram 1500. They are issued by Dahmler-Chrysler to instruct dealerships how to correct potential problems. They are not recalls.
http://www.nhtsa.dot.gov
Old 03-04-2006, 01:03 PM
mill500's Avatar
mill500
mill500 is offline
There's also a link above in the header with them as well.
Quick Reply: 2004 TSB's for Ram 1500
