Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down.
trouble codes!!
Old 02-26-2006, 08:27 PM
nicks2kes's Avatar
nicks2kes
nicks2kes is offline
Default trouble codes!!
what is P 0633 and P 0499?? help me !
Old 02-26-2006, 09:42 PM
bigham's Avatar
bigham
bigham is offline
Default RE: trouble codes!!
check here https://dodgeforum.com/m_328264/tm.htm
Old 02-27-2006, 12:27 AM
dodgejosh's Avatar
dodgejosh
dodgejosh is offline
if u have the ngc controller in ur car from the srt which i know u do the codes are as follows....p0633 is skim key not programmed... if ur key is junk or if u aint got a skim key then u need not fix it.. its for a security key(grey color key)... p0499 is nvld canister vent valve solenoid circuit high.... which could mean the the evap canister by the gas tank could be unplugged somwhere thats usually a circuit voltage high reading means.... theres ur codes hopefully it helps....i have ties to info being a tech
Old 02-27-2006, 03:10 AM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
633 is the code that everyone gets when they install the stage ecu's. it's nothing, don't worry about it. of course that is that you don't have a stage ecu then it's an issue. otherwise, it's just there to annoy you. won't throw a check engine light, but it's always there if you pull the codes up. the evap code is probably your gas cap. check it, make sure it's tight. then reset the ecu and see if it comes back.
Old 02-27-2006, 09:43 PM
bigham's Avatar
bigham
bigham is offline
and how do we check for codes
Old 02-28-2006, 04:31 AM
PSI Chick's Avatar
PSI Chick
cycle the key three times (not turning it on). the codes will appear where your odometer is.
Old 02-28-2006, 09:26 PM
bigham's Avatar
bigham
bigham is offline
just turn the key forwards all the way three times
Old 03-08-2006, 02:30 AM
jb20vtec's Avatar
jb20vtec
jb20vtec is offline
What does "bus"code mean?
Old 03-08-2006, 03:19 AM
PSI Chick's Avatar
PSI Chick
it's a relay issue. they're displayed as "U" codes instead of "P" codes. is this what you're getting?
Old 03-14-2006, 07:27 PM
Plan B's Avatar
Plan B
Plan B is offline
Soooooo.... if I cycle the key three times and nothing happens, does that mean I haven't thrown any codes or that I'm an idiot and I'm doing it wrong?
Quick Reply: trouble codes!!
