General Tech Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
trouble code P1687
Old 02-14-2006, 05:56 AM
marcus 1619's Avatar
marcus 1619
marcus 1619 is offline
Default trouble code P1687
Can anyone tell what this code is? Just popped up today, and i cant find the code anywhere P1687
Old 02-14-2006, 06:42 PM
marcus 1619
Default RE: trouble code P1687
nevermind i got it now, problem with oil pump
Old 02-15-2006, 12:50 AM
jeeper183's Avatar
jeeper183
jeeper183 is offline
p1687 NO CLUSTER BUS MASSAGE , pcm has not received an expected cluster status bus massage from instrument cluster within the last 20 second.
Old 02-15-2006, 01:58 AM
marcus 1619
OK thanks, i took it to autozone and they said it meant malfunction with oil pump. >><< So what exactly does that mean?
Old 02-15-2006, 03:12 AM
jeeper183's Avatar
jeeper183
ORIGINAL: marcus 1619
That means, they are not qualifield to diagnose your car , take it to your local dealer. BUS comunication problem is not understood by most "hole in wall" technician or salesman at "the zone"...
ps: is this a hard code( comes back as soon as erased ?) or interminent code ? does the cluster works ?
Old 02-15-2006, 03:17 AM
marcus 1619
I didn't erase it yet it's been going off by its self after about an hour then an hour later comes back on ETC< ETC
the instrument cluster has been working fine. The other day i had some glow race pedals hooked up , the guy hooked it to the running light headlight dash light switch. do you think thats all it is?
Old 02-15-2006, 03:35 AM
jeeper183's Avatar
jeeper183
That would be the FIRST place i would start!!!! disconect it , delete code and verify condition.
ps: what vehicle are we working on here ?
Old 02-15-2006, 04:55 AM
marcus 1619
2002 dodge dakota club cab 4x4 3.9 , THANKS FOR THE HELP!!!
[IMG]local://upfiles/27443/50C7217A0F5745208ADA0FD1F4580C85.jpg[/IMG]
Old 02-15-2006, 05:11 AM
marcus 1619
After i disconnect it , do you know where i can hook it back up or should just leave it off
Old 01-15-2007, 06:13 PM
aquatechpool's Avatar
aquatechpool
aquatechpool is offline
Hey I need help witht similiar problem...I had a no bus error on my odometer, and no gauges. I wasn't able to pull any codes so i took it to my dealer who charged me 91 bucks for the diagnosis and he said the the cluster had in internal fault and would have to be replaced to the tune of over a thousand dollars. So i paid the 91 and took to a friend whose a mechanic to take a look. He said there was a loose connection and now the problem is fixed. I'm pissed off now that i paid the diagnosis fee and now i feel they were trying to rip me off. Any ideas about this???
Paul
Quick Reply: trouble code P1687
