General Tech Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
P0320 code
Old 01-25-2006, 08:35 AM
npd_66's Avatar
npd_66
npd_66 is offline
Default P0320 code
My 2000 Durango has been showing code P0320 several times. This seems to be an intermittent problem (about every 3-4 days) and then works fine again. Vehicle doesn't want to start and then it will start by giving a little bit of gas. I have heard that some possible solutions are to replace the crankshaft sensor or the throttle position sensor. Can anyone give me a sepcific thing to try. I don't want to play trial and error by replacing a bunch of sensors if it is not needed.
P0320 - Ignition/Distributor Engine Speed Input Circuit
Old 01-26-2006, 11:52 AM
Junior5290's Avatar
Junior5290
Junior5290 is offline
Default RE: P0320 code
P0320 NO CRANK REFERENCE SIGNAL AT PCM
This code could be caused by a loose tone wheel, faulty crank sensor, PCM or in the wiring. Did any other code set.
Old 01-27-2006, 12:30 AM
npd_66's Avatar
npd_66
npd_66 is offline
That is the only code that it set. Is there any way to pinpoint the problem to one thing or is it just a trial and error deal. Also, do you know where the crank sensor is located? Is it easy to change? I can pick one of those up for about $25 so I think that it would be a cheap place to start if it's easy to change.
Old 01-27-2006, 11:12 AM
Junior5290's Avatar
Junior5290
What engine do you have?
Old 01-27-2006, 09:00 PM
npd_66's Avatar
npd_66
npd_66 is offline
4.7
Old 01-30-2006, 09:33 PM
npd_66's Avatar
npd_66
npd_66 is offline
Somebody help, please!
Quick Reply: P0320 code
